Ethanol damage!! Sherpa to XT petcock?
#67975
08/18/10 04:41 PM
Drifter
Posts: 102 |
Was reading last night and found that an xt 350 petcock from an 81 model will work on Sherpas the bolt pattern is the same does anyone know if any other years will work? I want a manual petcock with the sediment bowl at the bottom.
The vacuum petcocks on Sherpas and other bikes as well breakdown from exposure to this damn ethanol fuel and leak. From personal experience my Vulcan 500 did this and a full tank of fuel ended up in the bottom of the engine.... not good!! Others bikes have had the same problem not only Kaws. Sherpas are known to have this problem as well, my 01 started leaking last week so that petcock is going to be changed soon!!
Air Force Vet
Re: Ethanol damage!! Sherpa to XT petcock?
[Re: Drifter]
#67986
08/18/10 07:56 PM
Drifter
Posts: 102 |
Did some more research today and found... The xt 350 petcock with a sediment bowl is from 81-89 after that the sediment bowl was eliminated and it did not show up on the 225s either.
So Sherpa owners if you want a manual petcock order this part number 23F-24500-11-00 the gasket number 4x8-24565-00-00 CheapCycleParts has the petcock for 11 bucks the gasket is 2.15
Air Force Vet
[Re: Drifter]
#68115
08/20/10 06:38 PM
There are most likely a zillion parts out there that are interchangable from one bike to another, unfortunately, unlike in the used auto parts business, which uses the Hollander interchange manual, nobody has any reference source as to what is interchangable on bikes.
I personally hate vacuum petcocks, I've rebuilt the one on my '02 Vulcan 750 3 times since buying the bike new 8 years ago. But it's not just the petcocks, ethanol will damage all rubber and plastic parts of the fuel system. If you have a dirt bike with a vent hose on the cap, look how the end of the hose is swelled up. That's ethanol. I'm beginning to think ethanol is what destroyed the plastic tank on my XR400, and am now concerned about the Clarke tank on my XT225. Jerry.
[Re: JerryH]
#68118
08/20/10 06:51 PM
Fishwizard
Posts: 80 |
I run ethanol in my car and truck, but always try to avoid it in the bike and boat. The problem is, is that here in my area gas stations are either all ethanol, or 100% ethanol free. Not like, Nebraska where I'm from that had ethanol and non-ethanol choices at every pump, with usually the mid-range being the ethanol choice. The majority of stations here are all ethanol, and you often have to go out of the way to find an ethanol free station.
Are there any good fuel additives to counteract the affects of ethanol, or is simply an avoidance solution?
Ryan
2003 XT225
[Re: Fishwizard]
#68121
08/20/10 07:18 PM
Drifter
Posts: 102 |
I think i figured out how the fuel ends up in the engine. When the diaphram breaks down and leaks the fuel finds the hole and drains the tank into the engine through the vacuum port on the manifold. Or if bad enough and the tank is full up and out of the carb with fuel flowing out the overflow tube and into the intake manifold at the same time due to the high pressure in the tank.
If the vent hole is plugged or swollen up due to ethanol poisoning the pressure in the tank and be real high on a hot day so it actually blows the fuel into the engine....
Air Force Vet
[Re: Drifter]
#68130
08/20/10 09:50 PM
sear
Posts: 883 |
I don't think there's any choice in my part of NY State.
I've looked.
And if there are any places (short of my trying to top of my XT at the airport) that sell gasoline that doesn't have 10% ethanol in it, I'd probably run out of fuel before I got home from there.
So no choice here. How long will it be before these adulterated fuels available here start harming my bike's fuel components, and degrading its performance or rendering it inoperable?
2009 XT250 w/ 16T, 12 VDC socket, tank pannier, winged access screws "Safety is no accident."
[Re: sear]
#68134
08/21/10 01:32 AM
Chuck
Posts: 391 |
In my area regular grade gas (87 octane) may contain up to 10% ethanol but the high-test (91 Octane) isn't supposed to contain any ethanol
2007 XT225 Bone Stock Not so fat guy on a little bike
[Re: Chuck]
#68153
08/21/10 01:23 PM
Dahrkstorm
Posts: 619 |
This is a gas pump I ran across just inside the SD border on my trip in July. It sat right nexy to an E-85 pump. They call this pump a "blender" pump since it mixes the ethanol inside the pump. If you look at the pricing the more ethanol the cheaper the cost and for once the higher octane is cheaper. I of course used the least ethanol possible.
[Re: Dahrkstorm]
#68155
08/21/10 02:45 PM
Drifter
Posts: 102 |
pure-gas.org Stations listed by state that sell no ethanol gas. Those numbers on that pump are unbelievable i think i would find a new place to live!!!
Air Force Vet
[Re: Drifter]
#68161
08/21/10 05:27 PM
I don't have a choice, In AZ, ALL they are allowed to sell is 10% ethanol. Unfortunately I know of no way to prevent damage to the rubber and plastic parts of the fuel system caused by this stuff. You just have to replace the parts when they no longer work properly. I have 46,000 miles on my '02 Vulcan 750 (all mine), and while I have had to rebuild the petcock 3 times, I have never had the carbs apart, and it still runs fine. Jerry.
Topics16,841
Posts151,357
Members6,020
