Re: Shavings in oil filter
#363
07/22/05 02:56 PM
volare
Posts: 10 |
This information should be prominenetly displayed for new owners, of which I am one. I'm running out to buy a filter TODAY!
#364
07/22/05 03:30 PM
Montana Tracy
Posts: 1,058 |
Hi Volare, welcome to the site. Your "neer do well" in your profile seems to be nullified by your choice in the XT ... you did well! You don't have commas in your personal profile interests listing so at first glance it appears like you fly bluegrass motorcycles (sounds like a supercross rider who plays the slide dobro while pickin' and a grinnin' the banjo doing a backwards flip on an XT). Central Arizona seems like it would be a great place to ride. Enjoy!
Best Regards, Tracy
Straddle the saddle and live the adventure. '94 XT225 Yamamutt '06 Suzuki DR-Z250
#365
07/27/05 07:26 PM
JoeXT225
Posts: 363 |
After reading all of the posts on shavings in the oil filter I was prompted to go out and do an oil change and filter cleaning on mine. This was my first time removing the filter. Being a little unfamiliar with it, I accidentally punctured the fine mesh during removal and had to spring for a new one. There was some metal grit on the filter, but nothing excessive. It just looked like the filter was doing a good job at what it was supposed to do. I've changed the oil 3 times since new. This is the first filter change ( 04 model with 2,126 miles). I imagine the only problem you'd have is if the shavings/grit built up thick enough to limit oil flow through the filter. I've never had a problem removing the oil drain plug and have never seen anything of concern in the mesh basket at the drain plug. A good 19mm socket and a 1/2 inch drive ratchet have removed the plug with ease. I recommend not over tightening when reinstalling.
2004 XT225,Pro Moto Billet Aluminum Tail Rack W/ Chicane "Canyon" 19 l. bag, 16 LED aux. Brake Light, Kenda 761 tires, 12-volt power outlet, Fender Mounted Wolo "Loud One" Horn Upgrade, handle bar video camera /accessory mount, handle bar mounted watch, thermometer and compass. Garmin Nuvi GPS can be mounted in place of camera and powered using 12-volt outlet.
Topics16,841
Posts151,357
Members6,020
