rear foot pegs and mounting brackets
#146120
09/30/19 03:46 PM
CrozetVA
Posts: 18 |
I would like to buy the rear mounting brackets and footpegs for an XT225. Missing when I bought my bike.
2004 Yamaha XT225 2014.5 Kawasaki KLR650 2002 BMW R1100S
Re: rear foot pegs and mounting brackets
[Re: CrozetVA]
#146121
09/30/19 06:59 PM
Posts: 6,622 |
Parts diagram is HERE. All the parts and part numbers you'll need are in there. Stuff is listed as available too. Good luck.
#146138
10/02/19 07:05 AM
Posts: 2,114 |
My pillion pegs are missing also. I've been thinking of making some brackets from triangular ally 5mm thick should be ok, then buy some folding pegs off ebay for cheap.
Just need the dim's from each frame bolt hole to footpeg bolt hole.
[Re: CrozetVA]
#146140
10/02/19 02:43 PM
CrozetVA
Posts: 18 |
Let me know how that turns out.
[Re: CrozetVA]
#146142
10/02/19 03:25 PM
Posts: 2,114 |
Let me know how that turns out. Will do, need the dim's first.
[Re: Paul49]
#146144
10/02/19 08:08 PM
Posts: 4,168 |
Just need the dim's from each frame bolt hole to footpeg bolt hole. Let's try this... "H" means horizontal distance, and "V" means vertical. The others are straight line. I'm sure the geometry isn't exactly right as this is me with a tape measure... This is my 2006 US model. Right side: Left side: Dimensions:
[Re: CrozetVA]
#146150
10/03/19 07:16 AM
Posts: 2,114 |
Ayup peejman, thanks for your help with the dims, that's brill. I never thought the R & L might be different dims mount to pivot. I guess that puts the pegs at same height & position front to back of bike.
This can be one of my winter projects to stave off cabin fever. First job is templates, then getting hold of the ally, ebay mebbe or local Fab shop.
[Re: CrozetVA]
#146370
11/03/19 01:22 PM
Posts: 2,114 |
Had a horrible wet day yesterday, so got on with a bit of winter work early. So here's my first attempt at passenger footpegs Cost approx. £12 for a bit of aluminium & a pair of RE pegs all the way from India. And thanks to peejman for the dim's. You can also see in the pic my diy rear rack & the crap catcher under the number plate, that stops me looking like I had a bad curry after a muddy ride.
[Re: CrozetVA]
#146371
11/03/19 03:09 PM
CrozetVA
Posts: 18 |
Very nice. How thick is the aluminium plate?
[Re: CrozetVA]
#146372
11/03/19 03:30 PM
Posts: 2,114 |
It's 4mm, all I could get hold of, be strong enough for the grandkids weight. I will do a bit thicker for my mk2 version 5mm or maybe 6mm should be good for the missus. Ha, or a diet. Problem is bending the thicker material, I need a flypress, never have enough tools do we.
Topics16,841
Posts151,356
Members6,020
