Slow to turn over
#153340
06/03/22 08:43 PM
Jbishop89
Posts: 2 |
I have a 2014 xt 250 turns over slow and won’t start. Has new battery And lots of electrical parts for spark and what not. Just can’t figure out why it’s turning over slow and will only turn over once or twice then I have to let off the starter button and press it again. Does the same thing jumping the solenoid as well. Thanks in advance for input.
Re: Slow to turn over
[Re: Jbishop89]
#153341
06/04/22 03:06 PM
Muniac
Posts: 6,621 |
There are a couple of simple things you can do to check. You can run jumper cables from a running car (~13.6V) over to your bike's battery terminals. See if that changes your cranking speed. If it does, the battery is most likely the cause. If there is resistance between the battery and starter motor that can reduce cranking speed. On the XT225, the + terminal is accessible on the starter motor. You can jumper cable directly to that terminal and see if the starter cranks properly. The goal is to establish correct power levels in the starter circuit. Another idea is to measure (w/VOM) what voltage is actually at the starter motor. Perhaps someone can weigh in with what that would be on a XT250 bike that cranks properly. This does not address any mechanical issues that might be causing this problem. There could be problems with the motor itself. Both our bikes (2003 XT225) never had any starter motor issues in the 15k trail miles we put on those bikes. I always used Yuasa batteries. Good luck and I hope this helps.
[Re: Jbishop89]
#153343
06/05/22 08:29 AM
Paul49
Posts: 2,114 |
Check battery with multimeter, what voltage is it reading? You say it's new, could still be a bad one or low charge. Mine reads 12.8V, not ridden or charged for a week or so.
Current: 1958 Ariel 650 FH, 2014 Tiger Sport1050, 1995 XT225 Serow, 2016 Tiger 800 XRx.
[Re: Jbishop89]
#153344
06/05/22 02:47 PM
Muniac
Posts: 6,621 |
Hi Paul - Hope all is going well over on your side of the pond. It would be helpful to know your battery voltage when the bike is cranking. How far below OC (open circuit) voltage it reads gives a better indication of its cranking amp capacity. You are correct in that new doesn't always mean good. Ride safely.
[Re: Jbishop89]
#153345
06/05/22 06:51 PM
Jbishop89
Posts: 2 |
It had a bad ecu when I purchased the bike and the person I bought The bike from bought a ecu for it and the new ecu it turns over once Or twice. When I put the bad one on it turns over fine. Gonna check the battery in a bit to see what it’s reading
[Re: Jbishop89]
#153346
06/05/22 10:01 PM
Muniac
Posts: 6,621 |
I'm not familiar with the ECU function on a later model bike. The only thing I can think of is the plug firing is too advanced for some reason. That's an easy thing to check. Just disconnect the plug and see if the engine cranks through the compression stroke. If I recall, some older bikes would slightly retard the spark when cranking. That to avoid a kick back on the kick starter. Not sure what's going on.
OC voltage isn't necessarily conclusive of battery condition. The battery needs to maintain a certain voltage when loaded. I have no specs on that to share. Other than the tests I provided above. Good luck.
[Re: Jbishop89]
#153351
06/06/22 01:35 PM
peejman
Posts: 4,163 |
If the only thing that's changed is the ECU, that would be the first place I'd look.
This shall pass, be still and know. 2006 XT225, UNI filter, ProTaper bars, MSR handguards, SS front brake line, Shinko 241's.
42
guests, and 1
spider. |
Topics16,838
Posts151,340
Members6,014
