No chain slider #153310 05/27/22 10:55 PM
K
Kinseyd Offline OP
OP Offline
K
Guys,
On an XT225 video I saw a chain "slider" (to protect the swingarm) on the top and/or bottom of the swingarm. My 2007 XT225 doesn't have a slider on either the top or the bottom, not can I find a place to install hardware to hold a slider in place. Should I have sliders?
Thanks, Don
Don Kinsey
Re: No chain slider [Re: Kinseyd] #153311 05/28/22 01:53 PM
Y
youngfred Offline
Y
https://www.partzilla.com/catalog/yamaha/motorcycle/2007/xt225-xt225w/rear-arm
#13 - Still available
A bit pricy, though.
youngfred
2000 - XT225
Re: No chain slider [Re: Kinseyd] #153312 05/28/22 01:59 PM
peejman Offline
You don't want the chain rubbing on the swingarm. That guard isn't cheap, but its a lot cheaper than a swingarm.
This shall pass, be still and know.
2006 XT225, UNI filter, ProTaper bars, MSR handguards, SS front brake line, Shinko 241's.
Re: No chain slider [Re: Kinseyd] #153316 05/30/22 02:26 AM
J
JerryH Offline
J
If you mean part #13, yes you have to have that. Without it the chain will cut right into the swingarm. I had to replace that part on mine a few months ago. I was doing some other work on it, and while working on it that part just broke up into pieces and fell off. My swingarm is from a 1994 model, and it just dried out and rotted over the years. Yes it's expensive, but that is the least of your problems. You have to completely remove the swing arm, shock, and linkage assembly to replace it. And when I got everything apart, I found a bunch of other rubber and plastic parts that needed to be replaced. I spent 2 weeks and over $300 in parts replacing pretty much all the rear suspension bushings, spacers, and grease seals. The good thing is, now the rear suspension will outlast me. Besides the engine, the rear suspension is the hardest part of the bike to work on, mostly because of that complicated linkage. The first Yamaha single shock design just had the shock connected to the frame on one end and swingarm on the other, with no linkage. I had a 1979 DT250 like that and it worked fine.
The above is my opinion. Your mileage may vary.
1994/2001 custom built XT225 with a ton of aftermarket parts.
Re: No chain slider [Re: JerryH] #153320 05/30/22 06:56 PM
Y
youngfred Offline
Y
While you're down in-there check out the hidden Tensioner, #23.
https://www.partzilla.com/catalog/yamaha/motorcycle/2000/serow-xt225m/frame
Here's one on ebay with less parts than OEM.
https://www.ebay.com/itm/334403221818?hash=item4ddbfc393a:g:g3sAAOSwMf9iV4ic
youngfred
2000 - XT225
Re: No chain slider [Re: Kinseyd] #153328 06/01/22 05:02 AM
J
JerryH Offline
J
That is the part I was replacing when I accidentally broke the plastic/rubber chain guide on the swing arm. Mine was completely missing, though the bolt was still there, and did not show any damage from being hit by the chain. I didn't even know it was there. You could probably make one out of a rubber compression plug, but since I already had to replace so many other parts, I just ordered a new OEM one of those along with them.
Re: No chain slider [Re: Kinseyd] #153379 06/20/22 02:49 AM
K
kmccarthy Offline
Member L2
Member L2
K
The chain slider on my 2006 broke back in 2016. I made a post about it here:
http://www.xt225.com/forums/ubbthreads.php?ubb=showflat&Number=133329&page=1
I ended up ordering an aftermarket slider, with a split end, from hotfootmoto.com, so I didn't need to remove the swingarm. It was relatively easy to install and has held up fine for the last 6 years.
https://hotfootmoto.net/store/product.php?productid=18319
-kevin, XT225 2006, BMW F700GS 2013, 2020 BMW R1250GS
Re: No chain slider [Re: Kinseyd] #153382 06/20/22 08:07 PM
J
JerryH Offline
J
I didn't know about that one or I would probably have gotten it. But now that it's done, I'm glad I did it the way I did. When I removed the swingarm and linkage, I found a bunch of worn out parts that needed to be replaced.
0 registered members (), 12 guests, and 4 spiders.
Muniac 6,422
Az4x4 4,971
peejman 4,019
JerryH 2,115
Paul49 2,053
Topics16,674
Posts149,945
Members5,840
Jjona5, MissXTMayhem, WhisperingStream, Dangerous D, Steve201
5840 Registered Users
August
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 31
