WTS - 2013 XT250 Parts #151083 04/05/21 12:51 AM
M
Mike_G Offline OP
OP Offline
M
All parts listed below are from a 2013 Yamaha XT250 with about 16,000 miles. The parts are located in Raleigh, NC. Prices listed include shipping and are negotiable so if the price seems high, make an offer. If there is a part you need and don't see on the list please ask. Best to email me at mgar64@gmail.com
Photos of all parts are available here:
https://app.photobucket.com/u/Mike_G1964/a/58249ec2-dae5-4060-9418-67dc47e86fe2
3C5-22210-20-00 Rear Shock $180.00
5GT-81960-00-00 Rectifier Assy and Ignition Coil $100.00
1S4-82310-00-00
3C5-23103-20-00 Fork Assembly R $200.00
3C5-23102-20-00 Fork Assembly L $200.00
3C5-23435-00-00 Triple Tree Assembly $200.00
3C5-23340-10-00
3C5-83320-10-00
3C5-84315-00-00 Headlight Assembly $130.00
3C5-2580T-00-00 Brake Caliper Front $100.00
3C5-2580W-10-00 Brake Caliper Rear $100.00
5XT-2583T-00-00 Master Cylinder Front $75.00
5XT-2583V-10-00 Master Clylinder Rear $85.00
3C5-22110-00-00 Swingarm $200.00
5XT-11190-20-00 Cyl Head Cover $35.00
5XT-14871-20-00 Pipe 1 $25.00
5XT-11102-10-00 Cylinder Head $170.00
1S4-11311-01-A0 Cylinder $275.00
5XT-15411-02-00 Crankcase Cover 1 $50.00
5XT-15421-02-00 Crankcase Cover 2 $50.00
Front Wheel / Tire w/ brake disc $200.00
Rear Wheel / Tire w/ Brake brake disc $200.00
5XT-13907-10-00 Fuel Pump $200.00
3C5-24110-40-P0 Gas Tank $200.00
5VK-24602-30-00 Gas Cap $50.00
1YB-82590-00-00 Wiring Harness Assy $140.00
5XT-81410-10-00 Stator Assy $100.00
3C5-839-10-00 Handle Switch 2 $20.00
1YB-8591A-00-00 ECU Assy $130.00
1S4-83755-01-00 Speed Sensor $60.00
3C5-83371-00-00 Horn $20.00
4YR-81940-02-00 Starter Relay Assy $50.00
5VU-82576-01-00 Lean Angle Sensor $40.00
5JJ-81950-20-00 Relay Assy $15.00
1YB-83500-00-00 Meter Speedo Assy $150.00
5XT-13750-11-00 Throttle Body Assy $300.00
5XT-14803-20-00 Air Ind Sys Assy $100.00
4MY-83350-01-00 Flasher Relay Assy $30.00
5XT-16150-00-00 Primary Drive/Clutch Basket $150.00
5XT-13447-00-00 Oil Element Cover $20.00
5XT-13161-01-00 Delivery Pipe 1 $20.00
1YB-21110-00-00 Frame $300.00 Local Pickup only
3C5-21140-20-00 Frame Downtube $100.00
5XT-13581-10-00 Air Chamber $10.00
5XT-15415-00-00 Generator Cover $20.00
3C5-21315-20-00 Engine Stays $20.00
5XT-12210-00-00 Timing Chain Tensioner $30.00
5C1-82530-00-00 Stop Switch Assembly $10.00
5XT-82566-00-00 Side Stand Switch $25.00
5XT-83591-00-00 Thermo Unit $30.00
3LD-27411-10-00 Foot Pegs $20.00
3LD-27421-10-00
5D1-81950-00-00 RELAY ASSY (5D1-00) x2 $20.00
5XT-81952-00-00 RELAY HOLDER
5XT-21107-00-00 Tool Box
$10.00
3C5-26302-10-00 Throttle Assembly $20.00
3C5-27211-10-00 Brake Pedal $25.00
5XT-18110-10-00 Shift Pedal Assembly $40.00
5XT-18112-10-00
5XT-2217A-01-00 Relay Arm $40.00
Battery Band $10.00
Engine Bottom End $100.00 Local Pickup Only
5XT-16380-00-00 Push Lever Assembly $30.00
Re: WTS - 2013 XT250 Parts [Re: Mike_G] #151087 04/05/21 04:36 PM
Muniac Offline
Hi Mike - You've setup your album as private. Can't see any of the photos. Just a heads up. Good luck moving your parts.
Evolve & Simplify
Be There or Be Nowhere! A Few Adventures & Video
Re: WTS - 2013 XT250 Parts [Re: Mike_G] #151088 04/05/21 05:35 PM
M
Mike_G Offline OP
OP Offline
M
Thanks ... Had no idea. I have switched it to public
Re: WTS - 2013 XT250 Parts [Re: Mike_G] #151090 04/05/21 10:37 PM
Az4x4 Offline
That's better. Now we can see the parts. Good looking presentation. Parts look to be in great shape. Best of luck moving them, Mike..
..I'd rather have questions I can't answer, than answers I can't question.. Dr. Phil
Specialty Resource and DONATE
0 registered members (), 15 guests, and 1 spider.
Muniac 6,615
Az4x4 5,064
peejman 4,153
JerryH 2,152
Paul49 2,112
Topics16,829
Posts151,287
Members6,003
RickRandom, Krista, JimmyJam, gotwake5, Finchy
6003 Registered Users
March
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
