bike wont run if its not choked
#87037
09/15/11 05:45 PM
allagainstall
Posts: 278 |
1994 XT225
Re: bike wont run if its not choked
[Re: allagainstall]
#87038
09/15/11 05:52 PM
Tigersaw
Posts: 585 |
If it was ok but gone like this then blocked idle jet, blocked air filter. Do you have an inline fuel filter?
South UK
[Re: Tigersaw]
#87044
09/15/11 08:02 PM
If it was ok but gone like this then blocked idle jet, blocked air filter. Do you have an inline fuel filter? I also agree. But additionally you could look for an air leak between the carb and the engine. Alexd
[Re: alexd]
#87049
09/16/11 12:46 AM
allagainstall
Posts: 278 |
If it was ok but gone like this then blocked idle jet, blocked air filter. Do you have an inline fuel filter? I also agree. But additionally you could look for an air leak between the carb and the engine. Alexd this is what I was thinking.. I pulled the carb apart and cleaned all the jets, and the air filter. guess ill pull the boot off and inspect that next.
1994 XT225
[Re: allagainstall]
#87071
09/16/11 12:55 PM
allagainstall
Posts: 278 |
no fuel filter either. new poly tank. cleaned all the crud outta the tank. pulled carb off last nite, carb to head boot has cracks, but they dont go all the way through.
1994 XT225
[Re: allagainstall]
#87083
09/16/11 05:49 PM
It would be nice if you had a simple screen within your tank, and an external fuel filter (like the wonderful VISU-FILTER for $3.99) in the fuel line.
Anyway, the "damage" is done at this point, if there is a clog in your pilot circuit.
I would remove the pilot jet (usually #40) and blow WD-40 into the tube. I would be sure your pilot jet adjustment screw is 3 turns out, then button things up and try again.
[Re: alexd]
#87084
09/16/11 05:54 PM
Tigersaw
Posts: 585 |
cracks on the boot that dont go through. hmmm. Get it running and idling best you can, spray wd40 all over the boot. if it gets drawn in the idle speed will change. Bad cracks you'll see it seep in.
South UK
