Decided to upgrade the Front suspension on El Chupacabre.
went with Cogent Dynamics custom springs at .o46 rate and Racetech's Gold Emulator Valves.
I took pictures in case anyone else wants to do this to their XT.
you will need a drill press, some fork oil, a vise helps a lot, something to drive in your
fork seals, a set of picks will help, and a set of small files to deburr your damping rod after
you drill , you will also need a 1/4" drill bit.. and a stand for your bike.. duh.
this is a diagram of what you will be breaking down. its in the manual that you should have
take the fork cap off and press the silver cap down with a socket.
use something to get the clip out. the silver cap with come out easily.
dump the oil
remove this bolt. more oil will come out
remove the dust seal
remove this clip
jerk the fork tube out
remove the seal
remove the seal guide
remove the bushing
drink a bear that is as cold as the Rockies
examine the gutts
behold the Racetech diagram. it shows how to install the Emulators and where to
Drill the holes in your damping rods. Dont worry. If you Fck up you will just have to buy
another damping rod.. or 2 .
mark off your damping rods
Drill holes in your damping rods
