Re: DIY XT-225 valve adjust
[Re: RideOrDie]
#21689
05/28/07 04:13 AM
Mikuni
Posts: 146 |
Geez, I'm impressed. Thanks for the trouble you went to. I will definitely look through this several times.
Gap 0.6-0.7 mm
[Re: Mikuni]
#21697
05/28/07 06:24 AM
Toad225
Posts: 54 |
Thanks KLM!!! Wow!! Great! I can do it! Thank you so much!! Just got my used 2004 XT225 with 2700 miles on it. Don't think it's ever had a valve adjustment. In the week that I've had it, I have done the Z1 exhaust mod, turned pilot screw 3 turns out, and needed to replace seals in the fuel petcock. BTW KLM, I am in need of tires, what kind of tires are you using? They look mostly street/pavement which is more of what I need. Also, what luggage rack/side bags do you have? Thanks again!!
'04 xt225, WS's footpegs, Z1 mod
[Re: danno]
#21707
05/28/07 04:30 PM
Toad225
Posts: 54 |
Hey KLM, got another question. When you torque the valve lock bolts, aren't you concerned that the valve adjust bolt will turn just a hair? I am thinking that the valve tool will not fit when you torque the lock bolts, right? Thanks!
[Re: klm4755]
#21761
05/29/07 08:01 PM
meatball476
Posts: 8 |
It appears you did not need to remove spark plug?(the manual suggests to make turning ratchet easier)
Off subject-I purchased a large bottle of slime, but the instructions say for all tubless tires. The XT is tubed?
If you put the bike on a stand should you remove the skid plate?
05 XT225 Z1 Exhaust Mod. Dirtly Bar Risers Happy Trails Rack UNI Filter Wider Footpegs Pass. pegs removed Moose sealed bearings
"if u run you only die tired"
[Re: klm4755]
#23336
07/10/07 05:20 AM
RickMJr
Posts: 14 |
Wow, great thread! I adjusted my valves and it was easy. I hope you don't mind but I modified your instructions just a little (even added a couple of pictures) and created a PDF document. Can I upload this for everyone?
I'm so new...I don't know where to begin? 05 XT 225, devilman footpegs, magnetic drain plug, valves adjusted, pilot screw turned out 2 1/2 times.
[Re: RickMJr]
#23339
07/10/07 07:21 AM
joelberg
Posts: 346 |
Sounds like it would be helpful to me!
1992 Serow XT225, Z1'd my muffler @ 1", chopped the exhaust tip, 2007 blue plastic, UNI Air filter, removed snorkle.
1989 TW200 ***Wish List -New Rack(s) -Tire Chains
1995 Kawasaki Concours ZG1000, oversized 320mm dual front rotors
Dreambike: Plated KTM 530 EXC
[Re: klm4755]
#23389
07/13/07 02:15 AM
RickMJr
Posts: 14 |
OK, here's the PDF DIY valve adjustment instructions: DIY XT 225 Valve Adjustment.pdf Enjoy!
[Re: RickMJr]
#26513
10/13/07 03:14 AM
2007_XT225
Posts: 73 |
Did my first valve adj. today. Went well thanks to your tutorial.
At 360 miles the intake was fine and the exaust was little over one thousandths off.
I screws up only once during the whole process...I got that vacuum hose on the wrong side of the petcock, when putting the gas tank back on. Easy fix...just had to disconnect the fuel line and lift the tank up a bit and push the hose in its proper route.
Oh, I used a large coin (quarter) for the 2 round plastic plugs instead of a large flat blade screwdriver.
thanks keith.
- Steven
2007 Yamaha XT225 - Condotta's Cargo Rack - AFAM 16T CS Sprocket
[Re: 2007_XT225]
#26667
10/20/07 01:52 PM
Sonja & Gael
Posts: 23 |
Thanks KLM, that made it a breeze. Only took 30 minutes for the whole job.
At 1800 miles both valves were within the range.
Gael
2007 & 2003 XT225 - Z1 Stock Exhaust Mod - 3 turn pilot screw - Borrega Rear Rack - Cycle Rack Front Rack - Oversize Foot Pegs - 16T Afam Front Sprocket Currently traveling through Africa on 2 XTs, check out the site at http://www.gaelandsonja.com
[Re: Sonja & Gael]
#26674
10/21/07 02:13 AM
klm4755
Posts: 297 |
Gael No problem, Glad I could help. Keithm
Keith
