Re: Kick Starter on 2007
[Re: captaincrow]
#18856
03/11/07 07:26 AM
captaincrow
Posts: 193 |
Thank you lord for thinking about me, I'm alive and doing fine.
[Re: captaincrow]
#18857
03/11/07 07:30 AM
captaincrow
Posts: 193 |
The last posted pic is out of sequence. I need to take a potty break be back for more latter, wow 50 pounds lighter. Ok now we are almost at the top of the hill. just a little bit more to take off, then it will be down hill all the way. If you need to take a break, go ahead, if you got this far you deserve one. If you notice the hole for where the kicker shaft goes, the one on the left? just for grins, test fit your kicker sub assembly, then remover it for latter,
[Re: captaincrow]
#18858
03/11/07 07:48 AM
captaincrow
Posts: 193 |
Just above the hole for the kicker is a blank idler that must be removed. snap ring off first, then idler blank. follow the pics. I am learning here too!!!!
[Re: captaincrow]
#18859
03/11/07 07:54 AM
captaincrow
Posts: 193 |
[Re: captaincrow]
#18860
03/11/07 08:01 AM
captaincrow
Posts: 193 |
Final sub assembly pics these may be out of sequence please refer to your instructions for accuracy
[Re: captaincrow]
#18861
03/11/07 08:11 AM
captaincrow
Posts: 193 |
WOW! This is taking alot of time to load. I do belive it will be helpful, Kinda my way of paying back, all the info I have been given from this wonderful site. WELL, shall we continue.....holy empty file cabnet!!!.. I just realized I have not uploaded all of my kick strat files to photobucket. soo tune in next time,, same BAT time,,, same BAT channel. I will have the rest done very soon
[Re: captaincrow]
#18864
03/11/07 09:47 AM
captaincrow
Posts: 193 |
ok fellow xt'rs. I hope to get this finished up now you should have the idler in place and secured with snap ring. you are ready to put in the kick start shaft, you know it fits, because you test fitted it earlier,,right? notice the spring tab, it goes in the slot, right under the kick shaft hole, at the 6 o'clock poition, Now the dierctions say to wind the return spring one half turn, and hook it to the pin, see pic. I had to go one full turn to get the kicker to return to the proper poition. lets look at some pics........
[Re: captaincrow]
#18865
03/11/07 09:51 AM
captaincrow
Posts: 193 |
[Re: captaincrow]
#18866
03/11/07 09:55 AM
captaincrow
Posts: 193 |
[Re: captaincrow]
#18867
03/11/07 10:03 AM
captaincrow
Posts: 193 |
