Need help finding a rear brake lever pad that's la #153990 12/02/22 06:05 PM
jdag Offline OP
Got my wife a 2023 xt250 and need help finding a larger step pad for the rear brake. The larger the better. I can't find any specifically for some reason. Thanks
Re: Need help finding a rear brake lever pad that's la [Re: jdag] #153991 12/02/22 11:34 PM
flyinhawaiian968 Online Happy
Online Happy
Not sure who makes one, but perhaps this is a good thing for her to learn to keep them feet pointed in!
If you can't find one, and she's really adamant about having a larger pad, any welding shop should be able to cut the oem pad off and weld on a new pad, so just find any one that you think she'll be happy with that's in the same material as the new '23 (assume they're still steel and not aluminum).
1992 XT225
Re: Need help finding a rear brake lever pad that's la [Re: jdag] #153992 12/03/22 08:47 PM
P
Pumpguy Offline
P
So there's no misunderstanding about what is really wanted, I suggest you take a piece of heavy card stock, cut it out to the shape and size of the brake pedal tip you want. Ask the weld shop to duplicate it in sheet steel and weld it on your existing brake pedal.
Hope you come up with a good solution.
Re: Need help finding a rear brake lever pad that's la [Re: jdag] #153993 12/03/22 10:53 PM
She needs to learn to use the front brake, it does at least 75% of the work. The rear brake is for slow, slippery slopes and holding the bike stationary when stopped.
Muniac 6,569
Az4x4 5,025
peejman 4,094
Paul49 2,093
Topics16,761
Posts150,836
Members5,917
5917 Registered Users
