Page 155 of 155 1 2 153 154 155
Re: What did You do to Your Dual Sport today? [Re: Az4x4] #152702 12/31/21 09:04 AM
Originally Posted by Az4x4
Wow, that's a lot of tire you've fitted to the rear of your XT Paul! Looking forward to what you think of it after putting some miles on it. Hope it turns out well for you and doesn't rub where it shouldn't.. Best of the New Year to you and yours!..
Aye m8, 'tis a big & heavy tyre, had to try it for fit, not as much clearance as I'd like, we'll see eh. If it doesn't work I'll fit a MT21 same as front.
Best New Year wishes to you & all here.
Re: What did You do to Your Dual Sport today? [Re: Az4x4] #152703 12/31/21 05:25 PM
Out for a check run today 55 mile bimble for lunch up at Ladybower ressie, all fine, tyre not touched anywhere. Those big kbobbles feel a tad wobbly on road, be ok when they're worn in. Corners ok, just need get rid of the chicken strips, ha. Now I have good brakes both ends, makes for a quicker ride.
Re: What did You do to Your Dual Sport today? [Re: Drifter] #152704 12/31/21 11:17 PM
Sounds like you're good to go. We'll look forward to some pics. smile
Re: What did You do to Your Dual Sport today? [Re: peejman] #152711 01/02/22 10:21 AM
See in that pic below, the rubber section (top left) that keeps crud off the rear shock, is that a stock part, I can't see it on Fowlers parts list or else I'm looking in wrong sections. Not sure how long it should be, is mine worn away, should it reach down further?
[Linked Image from i.imgur.com]
Re: What did You do to Your Dual Sport today? [Re: Drifter] #152712 01/02/22 02:31 PM
Mine sits just even with the lower shock bolt and is just a piece of rubber about 1/8" thick.
Re: What did You do to Your Dual Sport today? [Re: peejman] #152713 01/02/22 02:52 PM
Thanks for looking & reply, that's it, mine must be worn away a bit, I'd fit a new one if I could find it in parts list, if only to help preserve the rubber cover on bottom of shock.
Looks to have a couple of moulded in pips from what I can see, that secure it. S'pose a bit of old inner tube would do the job if I can't get an original.
Re: What did You do to Your Dual Sport today? [Re: Drifter] #152716 01/02/22 11:49 PM
Finish up pretty much rebuilding the whole bike.
0 registered members (), 7 guests, and 3 spiders.
Muniac 6,308
Az4x4 4,951
peejman 3,911
JerryH 2,048
Paul49 2,026
Topics16,571
Posts149,160
Members5,753
XT250Girl08, tekkai, mkhach, JimJ, Slimslade33
5753 Registered Users
30 31
