Page 2 of 2 1 2
Re: 1999 Fork Pipes [Re: PackedPunches] #149932 01/08/21 06:08 PM
JerryH Online Content
The part number is different, but the '01 fork tubes fit the lower part of the fork on my '94. I wanted to keep the '94 lowers because they have a drain plug.
From that picture everything looks fine. If the fork boots are damaged, you might want to replace them. If dirt, sand or gravel gets between the boot and the fork tubes it can damage the tubes. All it takes is one little gouge in the tube and it will leak every time that spot passes through the seals.
Re: 1999 Fork Pipes [Re: JerryH] #149942 01/09/21 02:26 AM
P
PackedPunches Offline OP
P
Thank you guys! You guys are helping me get comfortable and understand my bike. You guys are amazing.
I also found a linkage rebuild kit for the xt 225 (only found one) it says its for years 05-2011 but I'm pretty sure they use the same linkage for all years (again slightly different part number) I'll put a link and see what you guys think of it because I know they're impossible to find
Swingarm Linkage Rebuild Kit?
Page 2 of 2 1 2
0 registered members (), 52 guests, and 1 spider.
Muniac 6,143
Az4x4 4,763
peejman 3,631
Paul49 1,912
JerryH 1,704
Topics16,313
Posts146,508
Members5,589
fillypeeno, Neil Cooper, Jeanette, 2wheelfun, kwcougs
5589 Registered Users
