Break off drain plug #145116 04/28/19 08:29 PM
Jrigdo710 Offline OP
My friends xt225ís oil drain plug is toast. You canít get a grip on it anymore, heís about to take it to the shop. Iím wondering if we could just break the plug off since itís aluminum? How would we do this and where can I find a replacement? I donít want to damage the engine
Re: Break off drain plug [Re: Jrigdo710] #145117 04/28/19 08:30 PM
It is a 1993 xt225, by the way.
Re: Break off drain plug [Re: Jrigdo710] #145123 04/29/19 10:07 AM
B
Bandit Offline
B
Can you get a grip on it with a pipe wrench or a pair of vise grips?I would not try to break the plug off.
2017 SUZUKI DR650
Re: Break off drain plug [Re: Jrigdo710] #145124 04/29/19 02:36 PM
I wouldn't try to break it off either. Too much risk of messing up the case.
Penetrating oil around the flange. Apply heat to the case but not the plug. Heat it until the oil starts to smoke, then stop and let it cool. Do that 3-4 times before you try to turn it. The heat cycles will help the oil get in there and break the joint loose.
Grip it with vice grips and tap the vice grips with a hammer. A manual impact driver might also work. Or, cut a slot in it, stick a cold chisel in the slot, put a wrench on the chisel, and tap the wrench with a hammer.
New plug...
https://www.ronayers.com/oemparts/a/yam/50043509f8700209bc78bc6d/oil-pump
p/n
Plug, Drain
5H0-15351-00-00
O-Ring
93210-347A1-00
Put a bit of oil on the threads of the new plug.
Re: Break off drain plug [Re: Jrigdo710] #145203 05/07/19 05:46 PM
Paul49 Online Content
Is it out yet?
Re: Break off drain plug [Re: Paul49] #147696 04/18/20 03:58 AM
He ended up taking it to a shop and the fixed it for him. Now his clutch won’t catch anymore. He kinda gave up on it and went for payments on a new bike haha.. oh well. Maybe he will fix it soon.
0 registered members (), 29 guests, and 2 spiders.
Muniac 6,010
Az4x4 4,533
peejman 3,434
Paul49 1,859
JerryH 1,550
Topics16,130
Posts144,598
Members5,463
AZrancher22, TamirG, Blueberries, rickrowls, Davide
5463 Registered Users
