Gearing and Tire size changes
#147371
03/22/20 12:52 PM
DennyLee11
Posts: 8 |
I'm toying with this idea... Run a 16 tooth (which is already installed) front sprocket and a 45 tooth rear sprocket and change my tires to a 40/60 (40% road/60% dirt) set up. If you ride mostly on the road wouldn't this set up give you a relaxed cruising speed and smoother ride? Anyone tried a set up like this?
Re: Gearing and Tire size changes
[Re: DennyLee11]
#147382
03/22/20 05:32 PM
I run 16/45 and Shinko 241's which I consider 50/50 tires. They're good in dry conditions, be that street or dirt. They're not so great on wet asphalt or significant mud.
[Re: DennyLee11]
#147394
03/23/20 01:58 AM
DennyLee11
Posts: 8 |
How does this gearing combination effect shift points and top end speed - cruising?
[Re: DennyLee11]
#147398
03/23/20 02:29 PM
At any given road speed, the engine rpm will be 6.7% lower with a 16 tooth front sprocket than a 15. The engine will also send 6.7% less torque to the rear tire at any speed. I find it helps make the bike a little happier on the street. It has a minimal effect on top speed. If anything, the bike will go a fraction slower due to the reduced torque and rpm. Engine rpm at a cruising speed of about 55mph will be about 400 rpm lower. This is a good tool to see the effect of gearing changes... https://www.gearingcommander.com/
[Re: DennyLee11]
#147406
03/24/20 08:33 PM
I think tire choice should be based on what you intend to use the bike for. I already tried the 16 tooth front sprocket, and it didn't work for me. The engine simply does not have enough power to pull a higher gear. It lugs the engine easier in all gears, feels sluggish, and has a slower top speed.
[Re: JerryH]
#147409
03/25/20 03:37 PM
.....I already tried the 16 tooth front sprocket, and it didn't work for me. The engine simply does not have enough power to pull a higher gear. It lugs the engine easier in all gears, feels sluggish, and has a slower top speed.. Everyone who's tried a 16 tooth front sprocket has an opinion on whether it's worthwhile or not. From personal experience I'm with Jerry on this. The little 223cc engine the XT225 uses " simply does not have enough power to (effectively) pull a higher gear." On the other side of the equation, going from the Yamaha's stock 15 tooth front sprocket to a 14 tooth, I ended up with a 1st gear I almost never used and a reduced top speed that was like throwing a speed limiter into the works. In some situations, namely riding rugged desert washes where finding a way through broken stream beds and loose rock slopes was a real chore, the 14 tooth made a name for itself. Otherwise, in everyday use, it was more hindrance than help. When I went back to the stock 15 tooth sprocket I realized Yamaha had precisely hit the 'sweet spot' with their out of the box gearing for the XT225, and after that I left it alone.
[Re: Az4x4]
#147436
03/26/20 07:57 PM
Posts: 2,113 |
I've been running 16/47 sprockets, so slightly higher than stock. I also run a 120/90 rear tyre, this can make quite a difference to the gearing. This set up is slightly over-geared.
People talk about the sprockets without saying what tyre size they use. My Brazil model (stolen) had stock 15/45 with a 110/80 tyre, that was under-geared for the road but good on the rougher trails.
I'm just changing the front to try 15/47, this with the 120/90 tyre should be a happy medium for road/trail use.....for me.
The stock 15/45 & 120link is, according to Gearing commander, a bad mix for wear.
What size tyre you running? A 16/45 might be ok with a 120/80 tyre, not tried that mix.
A 16T sprocket is cheap enough to give it a try, swap back if you don't like it.
[Re: DennyLee11]
#147473
03/30/20 09:53 PM
Selden
Posts: 373 |
My 2006 XT225 is running a 16 tooth countershaft sprocket, with stock size front, and a 4.10/18 rear. Both are Shinko 244 Golden Boy Trail tires. I can't imagine a better combination. On pavement, the engine is running at a comfortable RPM at 65-70 mph, and the tires do not squirm during fairly hard cornering. On dirt roads, the tread of the 244 tires provides good grip on loose gravel and mud, and I almost never have to use first gear.
[Re: DennyLee11]
#147516
04/02/20 06:56 AM
I almost never ride my XT at over 60 mph, usually closer to 55 mph on the road. About the only time I ride it on the pavement is to get to a place where I can ride it either off road or on dirt roads/trails. I have several street bikes for road use. IMO, as much as I love the XT225, it is not suitable as an only bike if you plan on doing a lot of road riding. The engine is too small to hold highway speeds, and the seat is almost unbearable on pavement. It does make a fine around town bike, especially if you install a luggage rack.
[Re: DennyLee11]
#147529
04/03/20 01:20 AM
Selden
Posts: 373 |
I don't think there is any "only" bike, although I can imagine a time in the not-too-distant future when the XT225 will be the last bike in my garage. I have a BMW F700GS (~460 pounds), which is much easier to handle than its predecessor, a 1999 R1100RT (~640 pounds), but the XT225 is so light and flickable that it is — by far — the most fun of the three. I just wouldn't want to ride it more than 100 miles in day, even on a modified seat. Compared with the XT, the GS too tall tall and heavy for dirt for riding someone my size (5' 6" ~145 pounds). The RT is great in cold weather and for long interstate rides, but it is a handful at low speeds, especially 2-up.
If by "highway speeds" you mean 4-lane, divided highway, I agree, but with a 16 tooth countershaft sprocket, an XT225 should easily hold 70 at ~6500 rpm. Above 75 the frame/tires/suspension become a little twitchy, but power is not the limiting factor. For mountain roads, it has enough power to handle anything I have encountered between 1500 and 3000 feet. With a carburetor, I would expect it to start gasping over 5000 feet.
