Cleaning / Polishing Aluminum especially Forks #146698 12/18/19 08:48 PM
JPouchet Offline OP
So when I got my 2007 XT225 home one of the first things I noticed in the garage - having purchased it at night - was the fork tubes looked a wee bit rougher than I thought when I picked the bike up in San Diego.
So I did some Internet searching and found a great video on YouTube of how to clean aluminum rims on an automobile.
Applied the basic concept to the forks.
Use 1 part distilled white vinegar
1 part isopropyl alcohol
and Steel Wool - fine or 00
Do wear rubber gloves! the mixture is acidic
Do place paper / rags under the work area the mixture will stain concrete
Oh - and don't use any plastic bowls that belong in the Kitchen. They will be a bugger to clean out afterwards! blush
Start at the top of the forks as the liquid will run down and help pre-soak the lower portions of the forks.
You may need to use a lot of pressure on certain areas. Keep scrubbing until you get the finish you are looking for. In my case this was a test. I'm happy but will revisit the process when I remove the front wheel for service. That will provide better access.
This is a 'before' view of the forks.
This is an after
Note: your results may vary. The good news is just about any degree of pitting / oxidation can be removed. Wish I knew about this when I lived at the beach with my Virago 750. Could have cleaned that up nicely.
Enjoy!
JP
Last edited by JPouchet; 12/19/19 12:16 AM. Reason: type - should be good not god news
Adding some Adventure to my life
Re: Cleaning / Polishing Aluminum especially Forks [Re: JPouchet] #146699 12/18/19 09:18 PM
Nice! The forks look a whole lot better than when you brought the bike home. Lot of work, no doubt, but well worth it..
"When it's a life-and-death matter, the market for bullshit drops to zero."
Re: Cleaning / Polishing Aluminum especially Forks [Re: JPouchet] #146702 12/19/19 09:33 AM
Thanks for the tip.
0 registered members (), 15 guests, and 0 spiders.
Muniac 5,942
Az4x4 4,456
peejman 3,373
Paul49 1,822
JerryH 1,541
Topics16,054
Posts143,918
Members5,405
dawndawnndawnnn, Brapbrap47, ArnoldB, Firearmor, Chezee
5405 Registered Users
March
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31
