XT250/350 stator coil #145561 06/16/19 04:47 PM
B
Bush Pig Offline OP
B
Hi.
I'm having a problem with the coil within a coil in my stator system, I think its the starter coil, forgive my ignorance, on my '87 xt225. It seems I will need to replace it. Have been offered one designed for an XT250/350 that looks like the same size, however will it work on the xt225. Yamaha parts on the Southern tip of Africa are extremely expensive so you try for the best price.
Bush Pig
Re: XT250/350 stator coil [Re: Bush Pig] #145617 06/26/19 02:05 AM
R
racer162 Offline
R
I recently encountered this. I think your referring to the pulsar coil.
I had to replace mine it was about $30 usd I believe.
When you replace it also replace that gasket. It will save you headache down the line.
Re: XT250/350 stator coil [Re: racer162] #145635 07/01/19 05:24 PM
B
Bush Pig Offline OP
B
Thanks
Bush Pig
Re: XT250/350 stator coil [Re: Bush Pig] #146194 10/12/19 02:12 PM
B
Bush Pig Offline OP
B
I've been told that my 1987 XT225 needs a new CDI and OEM ones are not available.
Any ideas about what to do now.
The part # is 1KH85540-M0-00
Bush Pig
Re: XT250/350 stator coil [Re: Bush Pig] #146196 10/12/19 02:18 PM
Re: XT250/350 stator coil [Re: Az4x4] #146199 10/12/19 05:57 PM
B
Bush Pig Offline OP
B
Thanks.
Bush Pig
Re: XT250/350 stator coil [Re: Bush Pig] #146200 10/14/19 02:12 PM
You might find one in a salvage yard.
Re: XT250/350 stator coil [Re: Bush Pig] #146380 11/05/19 08:28 PM
B
Bush Pig Offline OP
B
Sent it off to a very innovative young man who fitted a new after market CDI for the SA rand equivalent of $43. It doesn't look the same but it works the same.
Bush Pig
Re: XT250/350 stator coil [Re: Bush Pig] #146381 11/05/19 09:47 PM
That's awesome, Bush Pig. Glad you found an affordable solution to your XT225 issue. High five to the young fellow who scoped it out. Enjoy, and ride safely!..
Re: XT250/350 stator coil [Re: Bush Pig] #146382 11/06/19 01:25 PM
Cool. Glad you found someone to work on it.
1 registered members (Craig1), 26 guests, and 2 spiders.
Muniac 6,027
Az4x4 4,565
peejman 3,470
Paul49 1,870
JerryH 1,550
Topics16,159
Posts144,862
Members5,484
Teg, Mark's mechanics, Chris22, Mrs B-P, TribalHandyman
5484 Registered Users
July
