Page 1 of 3 1 2 3
Stall at idle when walking in reverse #146204 10/15/19 12:46 AM
N
NewRiderXT Offline OP
N
I'm not sure if this is a normal issue but I'm having an odd intermitent stalling when attempting to
walk my bike backward into a parking space.
It also sometimes happens with tight turn forward motion preceding the backwards motion, and I have to blip the throttle a bit to prevent a stall (which I'm often not quick enough to catch).
I can prevent the stall if I give it some gas before it actually stalls, but it seems kind of odd that I idle fine walking my bike forward, its just when trying to back it up that it happens?
Has anyone run into this? The only things that I can think of are:
  • Float Height
  • Clutch/Choke - both don't seem overly tightly routed
  • Idle not set correct - Not sure how to tune this to an actual rpm value... just going by ear it seems ok. I don't want to set the idel too high either...
Re: Stall at idle when walking in reverse [Re: NewRiderXT] #146206 10/15/19 07:37 AM
I would try adjusting the idle a minimal amount. Even if you were to accidently go a tad high out of spec, it wouldn't cause any issues.
Re: Stall at idle when walking in reverse [Re: NewRiderXT] #146208 10/15/19 03:00 PM
The bike has a wet disc pack clutch which has inherent drag. You can see that by the noticeable knock when going into first gear from a standstill. I would be interested in exploring your backwards move in neutral, clutch pulled in, etc. Just to see if any of these combinations make a difference. If the clutch is dragging (slightly) it might be just enough to overcome the engine's available torque at idle. Resulting in a stall. Going backward would pull against the engine's rotation.
I too thought about fuel moving in the bowl when back peddling. That would mean a very low fuel height. Causing a brief loss of fuel. But that would produce other symptoms which aren't present. Good luck.
Re: Stall at idle when walking in reverse [Re: NewRiderXT] #146212 10/16/19 12:14 AM
Try it in neutral. If it doesn't stall, could need a slight clutch or idle adjustment. If it runs fine otherwise, I'd say the carb is fine.
Re: Stall at idle when walking in reverse [Re: NewRiderXT] #146221 10/16/19 12:01 PM
Is this in gear with the clutch held in? If so, it's likely as muniac says & logical.
I've found some oils cause more clutch drag than others, eg Morris f/s m/c oil was bad, Silkolene semi less so. You likely use different oils over the pond. I would use the Mobil 1 that muniac uses, not stocked locally here.
Re: Stall at idle when walking in reverse [Re: NewRiderXT] #146223 10/16/19 03:07 PM
I've always used Mobil I 15W-50 with good results. The clutch slipping when using synthetic oil is a myth. I have noticed it wicking through O-rings, gaskets and seals more than dyno grade oils.
Re: Stall at idle when walking in reverse [Re: Muniac] #146225 10/16/19 03:45 PM
Is that the bike specific oil, or the general car oil?
Re: Stall at idle when walking in reverse [Re: NewRiderXT] #146227 10/16/19 04:53 PM
It's just the general non-specific oil. Comes in a light grey quart container marked "Advanced Full Synthetic". I think it's a good lubricant which I change out every 500 miles. I also use Mobil I synthetic grease (red color).
Re: Stall at idle when walking in reverse [Re: Muniac] #146229 10/16/19 05:06 PM
Thanks muniac, I'll do a google search again, see if I can get it, maybe posted. I got the same grease, good stuff.
Re: Stall at idle when walking in reverse [Re: NewRiderXT] #146241 10/17/19 09:12 PM
I'd be surprised if Mobil I isn't offered internationally. I like synthetic oils and grease. Amsoil is also a good choice if Mobil I isn't available.
Page 1 of 3 1 2 3
0 registered members (), 41 guests, and 2 spiders.
Muniac 6,008
Az4x4 4,531
peejman 3,429
Paul49 1,858
JerryH 1,550
Topics16,129
Posts144,575
Members5,459
5459 Registered Users
