Throttle Stutter #145855 08/15/19 06:40 PM
F
FatKidAndy Offline OP
F
When i go uphill or even on flat roads and give my xt a lot of throttle it will sputter until i let go of the throttle and try again. I recently, a few months ago, rebuilt the carb with all new jets and gaskets. replaced air filter. fresh spark plug and spark plug wire.
Clean the carb again?
Check the petcock?
Any thoughts or ideas would be helpful.
Re: Throttle Stutter [Re: FatKidAndy] #145856 08/15/19 08:36 PM
So if I got this right, after it sputters and you let go and try again, it runs fine and keeps pulling with no sputter?
Check the fuel flow out of the tank?
Check float level?
Stuttering with a lot of throttle tells me it isn't getting enough gas.
Re: Throttle Stutter [Re: FatKidAndy] #145858 08/16/19 12:08 AM
A
Aguaski Offline
A
Agree with skypupbob. Also make sure your tank is venting properly.
Re: Throttle Stutter [Re: FatKidAndy] #145859 08/16/19 01:30 AM
What year is it and what jets did you install?
Re: Throttle Stutter [Re: FatKidAndy] #145896 08/21/19 08:43 PM
F
F
UPDATE:
It stopped doing it. I believe the float got stuck. took apart the carb and cleaned it. Hasn't happened in a week or so.
Re: Throttle Stutter [Re: FatKidAndy] #145901 08/22/19 01:44 PM
Great! B-12 (Berryman) is good carb cleaner. It also doubles as instant insect/bee killer. Ride safely.
0 registered members (), 47 guests, and 3 spiders.
Muniac 5,887
Az4x4 4,421
peejman 3,336
Paul49 1,814
JerryH 1,522
Topics16,003
Posts143,492
Members5,376
NoBs, indigoer, Woodythedon, Peter UK, type918
5376 Registered Users
(Release build 20190728)
PHP: 7.3.14 Page Time: 0.011s Queries: 15 (0.004s) Memory: 2.8559 MB (Peak: 3.0968 MB) Data Comp: Off Server Time: 2020-02-17 12:09:30 UTC
Valid HTML 5 and Valid CSS
