Clutch slipping in 3rd and 4th #145805 08/08/19 01:05 AM
A
amoll Offline OP
A
Hello everyone,
When I engage my clutch after shifting into 3rd or 4th gear and accelerate hard, my clutch seems to slip. The engines revs very high without the acceleration I would normally expect, something is certainly off. If I accelerate gently, then the problem isn't that bad. I have tried adjusting the clutch lever/wire several times but it does not fix the problem. My bike is approaching 20k miles (3rd owner) and I was thinking maybe I should replace the clutch disks and springs. Is it normal for the clutch to wear out around then? What do you guys think could be the problem? Thanks in advance for any advice!
06 xt225
Re: Clutch slipping in 3rd and 4th [Re: amoll] #145819 08/09/19 07:31 PM
Clutch life depends largely on how the bike has been ridden. If not abused, a clutch can last well beyond 50k miles, but you can also burn one up in less than a minute.
The normal way to check for a worn clutch is to ride up to about 50 mph in 6th gear and whack the throttle wide open. If it's gonna slip, that's when it will. If your bike is slipping in 3rd or 4th gear... I'd say that's a good indication that it's done. Unless it doesn't slip in 5th and 6th too (which would be odd)?
Re: Clutch slipping in 3rd and 4th [Re: peejman] #145820 08/09/19 08:34 PM
^+1
This is what I'm not understanding. Should be slipping worse in high gear. confused
Re: Clutch slipping in 3rd and 4th [Re: amoll] #145825 08/12/19 01:49 PM
A
amoll Offline OP
A
I have been riding it pretty hard so it could certainly be the problem. I will bring it up to 6th and try what you said peejman, I think I may not have noticed it then because I don't open my throttle as hard as in 3rd and 4th. Thanks guys!
06 xt225
0 registered members (), 47 guests, and 3 spiders.
Muniac 5,887
Az4x4 4,421
peejman 3,336
Paul49 1,814
JerryH 1,522
Topics16,003
Posts143,492
Members5,376
NoBs, indigoer, Woodythedon, Peter UK, type918
5376 Registered Users
(Release build 20190728)
PHP: 7.3.14 Page Time: 0.011s Queries: 15 (0.003s) Memory: 2.8489 MB (Peak: 3.0968 MB) Data Comp: Off Server Time: 2020-02-17 12:32:33 UTC
Valid HTML 5 and Valid CSS
