Mechanical Tachometer #145595 06/23/19 01:13 PM
John Ellis Offline OP
Hope I havenít missed a post, but through searching all I could find are digital inductive tachs being installed. Recently saw a picture from a TAT page on FB with an XT225 with factory looking speedometer AND tachometer(believe itís from a DT125/175) but the guy posting didnít get any information or the riders name. Iím just wondering how difficult the install would be to have a gear driven, factory looking tach.
2007 XT225: intake/exhaust moded, 42.5/130 jets
Re: Mechanical Tachometer [Re: John Ellis] #145597 06/23/19 03:05 PM
If you did find an analog tachometer driven through a cable. Where would you tap into the engine for the cable? And how would this be calibrated? I think an electronic tachometer with an analog dial would be much easier to locate and install. You can derive a signal from the primary of your ignition coil. I'd guess the pulses per second would be a factor of 2 and a time base conversion to get engine RPM. That would all be in the tachometer's internals. Just a thought. Good luck!
Re: Mechanical Tachometer [Re: John Ellis] #145598 06/23/19 03:33 PM
Right, I understand all that and that is my question. DTs have a hole right near the oil pump on the front of the engine where the mech drive for the tach comes off. I was hoping to find this person as a member here to fill in the blanks. Iíd post the photo, but Iím not sure how to from my phone.
Re: Mechanical Tachometer [Re: John Ellis] #145608 06/24/19 02:38 PM
Imgur can provide a free photo hosting service and clean URLs which can be used here to embed photos. You'll upload to Imgur, get a link ending in .jpg or .png and use that to display your photo(s). From the Full Reply Screen, you'll use the 4th icon from the left.
On the XT225, I'm not aware of any holes (or gearing) in the engine case for a tachometer.
Re: Mechanical Tachometer [Re: John Ellis] #145612 06/24/19 11:43 PM
[img]https://www.amazon.com/photos/shared/6w33tssSQeaV7ogs1m2-ew.A1axtmC_DazY_0T0KCs6mL[/img]
This is the picture but it doesn't really answer any questions. Maybe someone will recognize the bike🤷🏻‍♂️
Re: Mechanical Tachometer [Re: John Ellis] #145801 08/06/19 05:55 PM
R
Rubicon Offline
R
Actually the picture answered everything.I was going to tell you that the XT350 has a mechanical tach and to look there for possibilities as the front wheel is easily put on the 225 because it is the same except for a larger brake rotor.The minute I saw the picture it is clear that is a 350.I would still advise you to pursue the possibility of adapting a tachometer from a 350.
Re: Mechanical Tachometer [Re: John Ellis] #145802 08/07/19 05:33 AM
R
Rubicon Offline
R
So I was confusing the tach cable with the speedometer cable. The wheel isn't the problem it's the engine and to be honest I've never missed having a tachometer on this bike.The only purpose I can imagine is knowing you are in sixth and not trying to shift into a seventh gear that doesn't exist.I do know people have put on the digital tachs and the only complaint is slightly slow response time.
Re: Mechanical Tachometer [Re: John Ellis] #145803 08/07/19 07:19 PM
B
BillV Offline
B
Those little tach/hour meters are cheap but I've heard about response time issues for years. They seem somewhat crappy. At one time I was considering this.
The size seems good for our bikes. I like all the options and a stepper motor ought to give better response (no guarantee). But not waterproof is a downside and will require some sealing.
Unfortunately, I've never pursued it any further.
2006 GSX-R1000 - Highway
Re: Mechanical Tachometer [Re: John Ellis] #145836 08/13/19 09:04 PM
B
BillV Offline
B
I was playing with the options for a different Speedhut 2 5/8" tach and came up with this today:
Not bad!
Re: Mechanical Tachometer [Re: John Ellis] #145854 08/15/19 06:39 PM
peejman Online Content
Car related tach's generally aren't set up to work with a single cylinder engine.
0 registered members (), 26 guests, and 1 spider.
Muniac 6,107
Az4x4 4,623
peejman 3,555
Paul49 1,880
JerryH 1,593
Topics16,248
Posts145,649
Members5,546
5546 Registered Users
October
25 26 27 28 29 30 31
