Starter grinding noises #145773 08/03/19 01:00 PM
A
American Greenz Offline OP
A
Hi All,
My starter on my XT225 is making grinding noises. I take it out and lube the back end of the shaft and reassemble. It works for about 2 months and then starts grinding again. There is no bearing on the back of the rotor. It appears to be metal on metal. I'm surprised the starter lasted as long as it did. About 12k miles.
Anyone have any ideas on why the starter appears to lose its lube? Maybe I need a high temp grease?? Also, anyone try those $40 starters on ebay? The factory part I believe is over $160.
thanks,
John
2007 XT225:Z1,Coleman Seat,M-Wave on Immix Rack,Signal Beeper,127.5m/42.5p,Uni filter, Iridium Plug, Turbo City Windscreen
Re: Starter grinding noises [Re: American Greenz] #145777 08/04/19 12:14 AM
Never had a starter give me problems on my XT225s, so I can't speak from experience. As far as buying online, read the user comments on the starters available and choose one with the most positive reviews. For the difference in price you can't go too wrong with that even if it isn't the far more expensive OEM Yamaha part.
"Never let your sense of morals get in the way of doing what's right." Isaac Asimov
Re: Starter grinding noises [Re: Az4x4] #145778 08/04/19 02:27 AM
A
A
I'm still struggling to understand what is going on with the starter. I rented the bike to someone and he called me and said it wouldn't start. I found the starter frozen and the battery dead. The only thing I can come up with is that he sold the original starter to someone. Not sure how the battery could go dead as well. I ordered a new starter from Amazon. I'll see how it works out.
Re: Starter grinding noises [Re: American Greenz] #145780 08/04/19 07:58 AM
#brer15 Online Content
A bushing has worn out to the point the armature is now coming in contact with the yoke (magnet barrel). You can probably see wear on the armature, and maybe even run your finger inside the magnet barrel and feel that it is not perfectly smooth (or perfectly round) any more.
I'm not sure if this has ever been documented happening on an XT starter, but most surprising to me that it is on a starter that only has 12,000 miles.
I don't have a lot of confidence in an aftermarket starter for $40. But keep us posted on how it works out. This would be a great starter alternative if it does work out.
1 registered members (#brer15), 70 guests, and 1 spider.
Muniac 5,901
Az4x4 4,430
peejman 3,346
Paul49 1,814
JerryH 1,522
Topics16,016
Posts143,603
Members5,383
TXxt225, Eyesenish, Nunny, doggie, JDon2whls
5383 Registered Users
