#145742 - 07/27/19 10:15 PM XT225 rear brake not working
Jrigdo710 Offline
Loc: Tn
We just replaced the rear brakes on 1993 xt225, now the brake doesnít even work. We took it off twice and tried putting it on different ways, and when pressure is applied it doesnít work. The piece inside the brake thatís supposed to turn just stays flat. The spring is tightened as much as possible, we just donít understand
#145743 - 07/27/19 10:45 PM Re: XT225 rear brake not working [Re: Jrigdo710]
As I recall, there's a cam in there which pushes the top of the shoes outward toward the drum. It's a very simple mechanism. A rod (from the cam) comes through the drum backing plate where there is a lever attached. This is pulled via a rod when pressing on the brake pedal causing the cam to rotate slightly. As for the drum, it's a cast iron sleeve pressed into the hub.
Is the drum sleeve worn excessively?
Did the rear brake work before you took it apart?
Does the lever rotate and move the cam?
Are the lobes on the cam worn off (or down)?
Did you reinstall the drum backing plate properly?
You can post some photos here which would help.
#145744 - 07/28/19 12:30 AM Re: XT225 rear brake not working [Re: Jrigdo710]
As Muniac says, it's a pretty simple mechanism. The splined shaft moves a lever that pushes the pads out against the drum. If that's working like it should, perhaps it's so far out of adjustment that the pads aren't touching the drum.
#145768 - 08/01/19 11:16 PM Re: XT225 rear brake not working [Re: Jrigdo710]
Selden Offline
Loc: GA
I assume this means that you removed the wheel, and examined the new brake shoes. Are you sure they were the correct parts? Can you elaborate on "The piece inside the brake thatís supposed to turn just stays flat"? A photo would help.
While the wheel is off, you should be able to move the brake lever by hand to see if the cam pivots and the shoes move. Other than wrong parts or mis-assembly, there isn't much that can go wrong with a rod-operated drum brake, a technology that goes back to the stone age of motorized vehicles.
1 registered (Bush Pig), 46 Guests and 3 Spiders online.
Muniac 5878
Az4x4 4397
peejman 3325
Paul49 1803
JerryH 1522
5373 Members
15985 Topics
Max Online: 279 @ 12/06/19 06:43 PM
Peter UK, type918, aquaholic, seanic, KngTyrannosaurus
5373 Registered Users
1 2 3 4
