Page 3 of 3 1 2 3
Re: 07 xt225 carb settings [Re: Chartman] #71584 10/31/10 07:22 AM
alexd Offline
Thanks for the charts! I had never seen these before.
Re: 07 xt225 carb settings [Re: Chartman] #71727 11/02/10 08:08 AM
kris Offline OP
i will do the checks as per your very good instructions and photos thank you
kris............ give me more mud
Re: 07 xt225 carb settings [Re: kris] #71729 11/02/10 08:22 AM
alexd Offline
If you use the "sight-tube" method, be sure to get the best screwdriver that you can find; many people are finding that stripping the float bowl's screw head, is not that hard to do.
Re: 07 xt225 carb settings [Re: Tigersaw] #145302 05/15/19 05:44 PM
Paul49 Online Content
Originally Posted By: Tigersaw
Heres my check of the fuel level - just a piece of pipe attached to the drain plug and curled round. The manual states it should be 11-12mm below the mating surface, mine here is almost level
And here is the reason - the float height measured at 12.5mm instead of 14.1-15.1mm
I modified the float height, it made a difference to the running as previously mentioned, though subsequent checks show the fuel level appears not to have altered enough, so I may revisit the adjustment another time
Vinduroman, see page 2 for pics of float bowl setting.
Page 3 of 3 1 2 3
0 registered members (), 23 guests, and 2 spiders.
Muniac 6,010
Az4x4 4,535
peejman 3,437
Paul49 1,863
JerryH 1,550
Topics16,131
Posts144,617
Members5,463
AZrancher22, TamirG, Blueberries, rickrowls, Davide
5463 Registered Users
