New front brakes grinding slightly. HELP #145239 05/11/19 02:55 PM
greyapron Offline OP
So I replaced my front brake pads yesterday and they seem to be scraping or dragging a tiny bit when the bike is rolling. Is this normal or Any ideas what I might have done wrong?
Jason. 94 XT225
Re: New front brakes grinding slightly. HELP [Re: greyapron] #145241 05/11/19 03:11 PM
They may make noise until they get bedded in. For safety sake lift the front wheel and give it a spin to make sure that it is not dragging. If it's ok then ride it a bit and see if the noise goes away after a few good stops.
Re: New front brakes grinding slightly. HELP [Re: greyapron] #145242 05/11/19 03:40 PM
How will I know if it is indeed dragging ?
Jason. 94 XT225
Re: New front brakes grinding slightly. HELP [Re: greyapron] #145243 05/11/19 05:00 PM
And how to I fix this problem ?
Jason. 94 XT225
Re: New front brakes grinding slightly. HELP [Re: greyapron] #145245 05/11/19 09:45 PM
If you can lift the wheel and spin it, and it spins freely (doesn't slow down real fast), then it is not dragging. If it were dragging, the rotor would get very hot when riding, even if you don't use the brakes.
Re: New front brakes grinding slightly. HELP [Re: greyapron] #145256 05/13/19 03:22 PM
What they said. A little dragging noise is normal. Ride a mile or so at moderate speed and then use the engine/rear brake to stop. Spit on the front rotor. If it sizzles, you've got a stuck piston. If not, its fine.
Re: New front brakes grinding slightly. HELP [Re: greyapron] #145421 05/27/19 09:54 PM
Thanks guys it's fine. I also changed the oil and replaced the speedometer cable. What fun that was getting it screwed in the bottom of the speedometer.
Jason. 94 XT225
Muniac 6,619
Az4x4 5,071
peejman 4,160
Paul49 2,113
Topics16,834
Posts151,323
Members6,009
6009 Registered Users
