#145116 - 04/28/19 08:29 PM Break off drain plug
Jrigdo710 Offline
Loc: Tn
My friends xt225ís oil drain plug is toast. You canít get a grip on it anymore, heís about to take it to the shop. Iím wondering if we could just break the plug off since itís aluminum? How would we do this and where can I find a replacement? I donít want to damage the engine
#145117 - 04/28/19 08:30 PM Re: Break off drain plug [Re: Jrigdo710]
Jrigdo710 Offline
Loc: Tn
It is a 1993 xt225, by the way.
#145123 - 04/29/19 10:07 AM Re: Break off drain plug [Re: Jrigdo710]
Bandit Offline
Loc: Rochester,New York
Can you get a grip on it with a pipe wrench or a pair of vise grips?I would not try to break the plug off.
2018 Yamaha XT250
#145124 - 04/29/19 02:36 PM Re: Break off drain plug [Re: Jrigdo710]
I wouldn't try to break it off either. Too much risk of messing up the case.
Penetrating oil around the flange. Apply heat to the case but not the plug. Heat it until the oil starts to smoke, then stop and let it cool. Do that 3-4 times before you try to turn it. The heat cycles will help the oil get in there and break the joint loose.
Grip it with vice grips and tap the vice grips with a hammer. A manual impact driver might also work. Or, cut a slot in it, stick a cold chisel in the slot, put a wrench on the chisel, and tap the wrench with a hammer.
New plug...
https://www.ronayers.com/oemparts/a/yam/50043509f8700209bc78bc6d/oil-pump
p/n
Plug, Drain
5H0-15351-00-00
O-Ring
93210-347A1-00
Put a bit of oil on the threads of the new plug.
#145203 - 05/07/19 05:46 PM Re: Break off drain plug [Re: Jrigdo710]
Loc: High Peak, UK
Is it out yet?
0 registered (), 38 Guests and 0 Spiders online.
Muniac 5697
Az4x4 4187
peejman 3177
Paul49 1714
JerryH 1516
5276 Members
15797 Topics
Odiegreen73, D2X250, ohhey, fedafedafeda, J-Young
5276 Registered Users
May
1 2 3 4
