Page 151 of 152 < 1 2 ... 149 150 151 152 >
#135696 - 02/18/17 02:05 AM Re: What did You do to Your Dual Sport today? [Re: Drifter]
I found a mud puddle on my way home from work. It's genuinely amazing how much better the bike looks with a bit of mud splattered across it. smile Apparently it's been a bit too long since I last got to play in the dirt. frown
#135697 - 02/18/17 08:10 AM Re: What did You do to Your Dual Sport today? [Re: Drifter]
Loc: High Peak, UK
All the cleaning is worth it after a good day off-road. Last time out on the Serow The bike & me were caked in crud. Me above the knees on me boots & textile pants, had to hose them off, the bike took an hour of cleaning. I hadn't been anywhere off-road just the country lanes. They were covered in mud, cow crap, grit & that sticky molasses salt mix the councils spread for ice, sticks like crap to a blanket, everywhere. All that cleaning for a road ride.
#144242 - 02/03/19 04:24 PM Re: What did You do to Your Dual Sport today? [Re: Drifter]
yeendy Offline
Loc: uk
hi, while out for a short winters ride , I was practicing riding in rutts and promptly rode the bike and me into the hedge , more practice required I think! grin
#144302 - 02/07/19 02:05 PM Re: What did You do to Your Dual Sport today? [Re: Drifter]
rocmoc Offline
Loc: So Az
Going out tomorrow. Has been wet and cool here in Southwest (yes I know nothing like the rest of the country has endured) but we will have one day of 70 degrees. Jumping on the XT and taking a 70+ mile all dirt off-road ride. I rarely clean my toys as I prefer the dirt over water in seals & bearings. I do use a spray bottle & wipe off.
rocmoc n AZ/Mexico
#144728 - 03/27/19 11:56 PM Re: What did You do to Your Dual Sport today? [Re: Drifter]
ThumperStorm Offline
Loc: St. Cloud, MN
Today I installed a Clarke tank onto my "01 XT225. I bought the tank last summer and finally got around to putting it on. It turns out that one of the brackets for the side cover was missing so I had to make one. Then the one for the other side didn't line up and I had to make some bends in it.
The fit isn't to bad, I think I might have to tweak it a little. The forks just touch the tank when turned all the way to either side. The top part of the seat isn't quite flush with the tank.
Not a big deal though and I'm quite pleased with it. It's not leaking and I think it looks good. I haven't filled it all the way up yet so I don't know how that will feel when riding it.
I put on a new fuel line and added an inline filter to it. I don't know how necessary that is but did it anyway. I like having it there and the fuel seems to flow just fine so far.
"Maybe you ain't in a rut, maybe you're in a ditch, way over your head." Don Marshall
#144780 - 03/30/19 11:12 PM Re: What did You do to Your Dual Sport today? [Re: Drifter]
Rick Mc Offline
Loc: Portsmouth, VA
Just install Kenda Trackmasters, 15/50 sprockets, X-ring chain, removed the turn signals, and inverted the rear brake rod.
XT225 by Rick McNelly, on Flickr
XT225 inverted rear brake rod by Rick McNelly, on Flickr
--Rick
2007 XT225, K&N, 130/42.5/2.7 turns, drilled slide vacuum port to 7/64, shimmed needle, Z1 mod, 14/50 sprockets, kick start
#144815 - 04/01/19 11:10 PM Re: What did You do to Your Dual Sport today? [Re: Drifter]
Rick Mc Offline
Loc: Portsmouth, VA
Did the Z1 exhaust mod today, drilled it to 1-1/2Ē.
I didnít think the increase in noise was objectionable, and the engine certainly felt more peppy. Seemed like there was more tug on the handlebars when nailing the throttle, and pulled very well from low rpms.
My bike originally had a 42.5 pilot and 130 main when I rebuilt the carb (previous owner did this in Alaska). I initially replaced both jets with new ones of the same size, but then changed the 130 main to a 127.5 and it ran fine. The bike has a K&N filter which feels like it is stuck, but I havenít tried that hard to pull it out.
With the jetting, K&N, 15/50 sprockets, and now the Z-1 mod, the bike has more snap to it than expected for itís displacement.
Iím really pleased at how this little bike is coming together.
--Rick
#144820 - 04/03/19 12:01 AM Re: What did You do to Your Dual Sport today? [Re: Drifter]
Today I replaced the vacuum port cap on the carb intake boot.
A few days ago it was nice so I rode to work. When I started the bike to go home, it made a little pop just as it fired and I could tell something was suddenly amiss in the fuel mixture. It popped a bunch while engine braking (which it very rarely does) to the stop sign a couple hundred yards away, and promptly stalled as soon as I stopped. It was unhappy about restarting, but finally did so with full choke. Same thing at the next stop sign. I switched to reserve with no effect and decided to stop at the gas station just up the road to see what I could see, and I needed gas anyway.
In the couple minutes It took to get there, I got the idea that it was behaving as though there was a big vacuum leak. I wondered what could have broken. I gave it a look over at the gas station and thankfully I fairly quickly noticed the end of the brass vacuum port poking out. The cap had dry rotted and the tip cracked and fell off. Ah ha. That would indeed make for a big vacuum leak.
So I dug around in my tail bag and found the roll of electrical tape I keep stashed in there. A couple minutes and a couple burned knuckles later, I got the port mostly taped over. The bike started right up and ran mostly normally the rest of the way home. I wasn't sure how long my tape job would last but it was still there and only a little melted when I got home.
I happened to have a leftover plug from something else that fit, so I put a new one on. I'll also add this to my "replace annually" list with the fuel line, filter, brake fluid, etc.
#144821 - 04/03/19 01:54 AM Re: What did You do to Your Dual Sport today? [Re: Drifter]
Loc: idaho
Good roadside repair!
A true backfire with the throttle closed has got to be a lot of pressure, and I've had them blown off so it's good to check them annually.
#145182 - 05/05/19 12:15 AM Re: What did You do to Your Dual Sport today? [Re: Drifter]
Loc: St. Cloud, MN
It was a really nice day out and I went out to the garage to add some things to my '01 XT225. First I put on some footpegs I got from DMO Specialties. I never minded the stock pegs but now that I have on the bigger ones on I'm quite happy with them. They are comfortable and my feet can shift and stop just fine without any adjustment needed.
I then put on some new grips. They are the Progrip 714. I like them. They are thicker than the ones that came off and feel much better in my hands. I'm hoping they will also help cut down on the vibration on longer rides. I used hairspray for a lubricant and glue. I've used that before on other bikes so hopefully it will work again.
While putting them on I also put on some Tusk Flex-D handguards. They went on pretty easy but I did need to take off the cross piece on the handle bars to get a good fit. I don't mind not having the cross piece on. My brake lever is bent from the previous owner so I cut the ball off the end to help with the fit. The aluminium bars on the handguards are very sturdy and I thought they were heavy for their size. They are roomy with plenty of space for my hands.
I also put on some folding mirrors. I bought them off ebay for $13 for a pair. I really like them so far. They seem strong and I can see better around my shoulders than with the stock ones. They do vibrate a little but not to bad. I've had other bikes where the mirrors vibrated a lot worse. They even came with the adapter for the Yamaha reverse thread. I'm happy with them, especially for the price. Time will tell how they hold up.
Last of all I put on a luggage rack I got from Ferreus Industries. It went on super easy and I like the way it fits close to the bike. I plan on camping with the bike and it will be great to have the space to strap things to. It feels kind of heavy, it's steel, and seems really strong. I've read reviews that say the powdercoat flakes off easy, so there is that. I'm not worried about it.
I've had some of these parts for awhile and it is nice to finally have them on the bike.
0 registered (), 27 Guests and 2 Spiders online.
Muniac 5737
Az4x4 4229
peejman 3207
Paul49 1715
JerryH 1516
5314 Members
15849 Topics
TS14, C-Dogg925, cde, Firehose, Tommy Gunzz
5314 Registered Users
July
1 2 3 4 5 6
28 29 30 31
