#143700 - 12/03/18 11:42 AM Oil leak into stator cover
JohnT Offline
Loc: UK
On removing the Stator cover on my 1986 Serow to check the electrics, I noticed everything was covered in oil. Resting the bike at an angle on the side stand, about a quarter of a pint of oil drained out from behind the flywheel onto the floor !!. The bike hasnít run for 10 years so Iím guessing an oil seal has failed but I cant seem to identify it on the parts list.
Can anyone identify the seal please and do I need to split the crank cases to replace it ?
All advice gratefully received.
#143704 - 12/03/18 06:25 PM Re: Oil leak into stator cover [Re: JohnT]
Loc: idaho
There is no seal! The stator runs in oil, so all is well.
#143705 - 12/03/18 06:41 PM Re: Oil leak into stator cover [Re: JohnT]
Yep. A small amount of oil in there is normal. Good that it ran out and wasn't sludgy or coked up from being too hot.
#143708 - 12/03/18 11:15 PM Re: Oil leak into stator cover [Re: JohnT]
JohnT Offline
Loc: UK
Thanks guys, that's the best news I've had today. New CDI on order which I'm fervently hoping will solve the lack of spark problem, then who knows, it might actually start !
#143709 - 12/04/18 05:34 AM Re: Oil leak into stator cover [Re: JohnT]
Reggie Offline
Loc: Lancashire, England
Hi John,
fingers crossed for you.
#143716 - 12/04/18 08:05 PM Re: Oil leak into stator cover [Re: JohnT]
Loc: idaho
Something to check on the stator if you have no spark. I think it is the yellow and brown wires coming from the stator should read between 875 and 975 ohm's. Mine was having intermitent spark problems and a test showed 1000 ohm's. I replaced the stator and it has great spark all the time. BTW the new stator read 950 ohm's.
Something to check, good luck!!
#143727 - 12/05/18 10:54 PM Re: Oil leak into stator cover [Re: skypupbob]
BigSm0ke Offline
Loc: QLD, Australia
^This!
The race was definitely underway. I had witnessed the start, I was sure of that much. But what now? What comes next?
Muniac 5607
Az4x4 4130
peejman 3046
Paul49 1647
JerryH 1511
5226 Members
15692 Topics
5226 Registered Users
24 25 26 27 28
