Page 1 of 2 1 2 >
#143494 - 11/07/18 03:24 PM XT250 Rack
Qwazert Offline
Loc: Lower Rainland BC
It seems that all I do is build racks for these...
Unfortunately, I can't adapt the 225 version on my rear-rack...does anyone have any plans for the 250?
http://dr650rider.blogspot.ca/
2009 XT250, 2010 DR650
#143495 - 11/07/18 06:42 PM Re: XT250 Rack [Re: Qwazert]
Reggie Offline
Loc: Lancashire, England
Hi Qwazert,
I use the Happy Trails rear rack myself and I'm very happy with it.
I can send photo's to you if it helps?
#143499 - 11/07/18 11:49 PM Re: XT250 Rack [Re: Qwazert]
Qwazert Offline
Thanks Reggie, but I'm more of a DIY guy...thought maybe someone would have some suggestions.
I already have an idea of how this is going to play out, just looking for a different perspective.
#143500 - 11/08/18 02:10 AM Re: XT250 Rack [Re: Qwazert]
Reggie Offline
Hi Qwazert,
good luck and I look forward to seeing your project developing.
#143510 - 11/09/18 07:54 PM Re: XT250 Rack [Re: Qwazert]
Qwazert Offline
OK...looks like I'll be taking matters into my own hands.
Let's go!
(Each of the LINKs below the pic, takes you to a full-size version...sorry I don't know how to do it otherwise!)
First, I remove the grab bars to access a secure mounting point. Then I install some "stand-offs" to bring the mounting holes outside of the plastics.
The stand-offs are nothing more than 3/4" Aluminum dowel, drilled through and tapped to 8mm.
Then I insert a length of "Reddi-rod" and Loc-tite it into place:
LINK
The threaded rod goes in about " into the dowel.
Once installed onto the bike, it looks like this:
LINK
In this particular case, I will have to go back to the lathe and shorten the front dowels by about 3/8". My initial measurements were "rough" and I knew there was a chance that I would be going back to the tools to fine tune.
This shows the mounts on the muffler side, as well as how I reformed the plastics to accommodate.
LINK
Then I notched out the exhaust shield so that this future rack would fit, without rubbing on the shield and causing more noises!
LINK
What the left side looks like:
LINK
So now that I have mounting points, I can design a rack to fit. The rack frame will require some "geometry" in order to miss some components...it will probably be shaped something like this:
LINK
Crude, basic layout...finished product will be curvier and more appealing.
Instead of the " aluminum stock that I used last time, I will probably opt for the 3/16" or maybe even 1/8" risers. The one I made for the XT225 was overkill AFAIC.
...more to come.
Edited by Qwazert (11/09/18 08:10 PM)
#143511 - 11/09/18 09:18 PM Re: XT250 Rack [Re: Qwazert]
Reggie Offline
Hi Qwazert,
keep up the good work.
#143513 - 11/10/18 01:36 AM Re: XT250 Rack [Re: Qwazert]
Loc: Atlanta,GA
Excellent work!
#143519 - 11/10/18 03:56 PM Re: XT250 Rack [Re: Qwazert]
Rear racks are really handy. Nice addition to your bike.
#143520 - 11/10/18 06:20 PM Re: XT250 Rack [Re: Qwazert]
Qwazert Offline
After *MANY* attempts, I came up with this semi-successful mock-up:
LINK
I say "semi-successful" because it obviously needs to be just a bit taller...which I will accomplish by extending the legs a wee bit and moving the mounting holes DOWN about ".
The legs are 60 from perpendicular and the rear deck of the rack is 30 from flat....two different angles, which makes things "interesting".
Painted, with a contrasting background:
LINK
Now, I'm going to take the dowels in and turn them down a bit...then maybe have a look at what sort of material to use to make these brackets.
Edited by Qwazert (11/10/18 06:21 PM)
#143522 - 11/11/18 01:10 AM Re: XT250 Rack [Re: Qwazert]
Nice!
Page 1 of 2 1 2 >
2 registered (Rick Mc, amoll), 34 Guests and 1 Spider online.
Muniac 5663
Az4x4 4163
peejman 3125
Paul49 1684
JerryH 1516
5263 Members
15757 Topics
gsmith, Andy74, SimonB, JoseXT, Vinduroman
5263 Registered Users
1 2 3 4 5 6
