Page 2 of 2 1 2
Re: play in rocker arms [Re: Paul49] #143473 11/05/18 08:50 PM
Reggie Offline
Originally Posted By: Paul49
Originally Posted By: peejman
I've never replaced that washer, but it doesn't leak.
Mebbe I've squashed it to death.
Hi Paul,
could one be a tad heavy handed?
Re: play in rocker arms [Re: Reggie] #143474 11/05/18 09:10 PM
Originally Posted By: Reggie
Hi Paul,
Ayup Reggie, Ha, I try not to be 'cos it's a weakened bolt, ya might remember some time back, I drilled the bolt down the centre & then in from the side near the head to meet that hole. The idea being that the oil flowed with a turn or two of the screw instead of being screwed out more to bleed. Seemed a good idea at the time. Seems it just needs a good washer not a 10 times reused/flattened one cos I change oil & filter every 600'ish miles. It uses a bit anorl, mebbe 150ml to 350 miles. I should write to Yamaha about this.
Re: play in rocker arms [Re: Bluedog] #143483 11/06/18 04:35 PM
Are either of the seating surfaces worn? If they're not flat, it would take a good bit of squish for it not to leak. I just tighten it snug so its not leaking and call it good. Given that the threads in the head can be delicate, I go easy on it.
Re: play in rocker arms [Re: Bluedog] #143484 11/06/18 04:55 PM
It's fine now m8 thanks, new washer fitted.
Page 2 of 2 1 2
0 registered members (), 37 guests, and 3 spiders.
Muniac 6,200
Az4x4 4,868
peejman 3,749
Paul49 1,954
JerryH 1,861
Topics16,435
Posts147,805
Members5,643
PrairieMilkman, Jbishop89, J. Sanchez, emcreeger, boostedbox
5643 Registered Users
May
30 31
