Page 2 of 2 1 2
Re: play in rocker arms [Re: Paul49] #143473 11/05/18 08:50 PM
Reggie Offline
Originally Posted By: Paul49
Originally Posted By: peejman
I've never replaced that washer, but it doesn't leak.
Mebbe I've squashed it to death.
Hi Paul,
could one be a tad heavy handed?
Re: play in rocker arms [Re: Reggie] #143474 11/05/18 09:10 PM
Originally Posted By: Reggie
Hi Paul,
Ayup Reggie, Ha, I try not to be 'cos it's a weakened bolt, ya might remember some time back, I drilled the bolt down the centre & then in from the side near the head to meet that hole. The idea being that the oil flowed with a turn or two of the screw instead of being screwed out more to bleed. Seemed a good idea at the time. Seems it just needs a good washer not a 10 times reused/flattened one cos I change oil & filter every 600'ish miles. It uses a bit anorl, mebbe 150ml to 350 miles. I should write to Yamaha about this.
Re: play in rocker arms [Re: Bluedog] #143483 11/06/18 04:35 PM
Are either of the seating surfaces worn? If they're not flat, it would take a good bit of squish for it not to leak. I just tighten it snug so its not leaking and call it good. Given that the threads in the head can be delicate, I go easy on it.
Re: play in rocker arms [Re: Bluedog] #143484 11/06/18 04:55 PM
It's fine now m8 thanks, new washer fitted.
Page 2 of 2 1 2
1 registered members (apenland01), 36 guests, and 2 spiders.
Muniac 6,119
Az4x4 4,671
peejman 3,578
Paul49 1,884
JerryH 1,593
Topics16,272
Posts145,850
Members5,565
Kansaspunkcore, Sheabird, Stroppyjock, Krummyrider, YamahaSam
5565 Registered Users
November
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30
