1993 xt225 brake light not showing up
#142926
09/11/18 02:53 AM
Jrigdo710
Posts: 20 |
My friend just bought an xt225 and when he hits his brake, either one, the rear light doesn’t glow up like it should.
Re: 1993 xt225 brake light not showing up
[Re: Jrigdo710]
#142927
09/11/18 03:20 AM
Posts: 11,645 |
Hi There,
first question, have they changed the bulb?
If so then check the switches (unlikely for both to fail at the same time), then check the wiring to the lamp and, if power is getting through then check the bulb holder.
[Re: Jrigdo710]
#142932
09/11/18 06:02 PM
Does the tail light work?
As Reggie says, it's 2 dual filament bulbs. Its possible the brake light filament is burned out.
Check the wiring going into the housing, the brake light wire could have come loose.
The wire could be damaged or broken somewhere along the length.
[Re: Jrigdo710]
#142937
09/12/18 02:34 AM
Jrigdo710
Posts: 20 |
Thank you all very much. Will check it and return in a bit.
[Re: Jrigdo710]
#142954
09/13/18 11:17 PM
Jrigdo710
Posts: 20 |
So, the problem on his bike is that the little pin that’s connected to the rear brake isn’t going in all the way. Is electrical contact cleaner safe to lube it with? Or should I just order a new one
[Re: Jrigdo710]
#142955
09/14/18 01:08 AM
You can use contact cleaner on that.
[Re: Jrigdo710]
#142957
09/14/18 12:28 PM
Yep. Contact cleaner, WD-40, compressed air, brake cleaner... whatever gets the gunk out. A replacement switch is cheap too.
