#142762 - 09/03/18 03:19 PM XT250 fuel filter
Qwazert Offline
Loc: Lower Rainland BC
...has anyone installed one?
How did you do it....there isn't much hose between the petcock and the carb!
http://dr650rider.blogspot.ca/
2009 XT250, 2010 DR650
#142763 - 09/03/18 03:32 PM Re: XT250 fuel filter [Re: Qwazert]
Reggie Offline
Loc: Lancashire, England
Hi Qwazert,
I used a small, in line filter from Toyota to fit to mine.
When I pick up my next XT250 Serow S on Friday, I'll have a look to see if the same filter will fit the fuel injected model and I'll let you know.
#142766 - 09/03/18 04:02 PM Re: XT250 fuel filter [Re: Qwazert]
Qwazert Offline
Mine isn't fuel injected.
I seem to recall on my ex-XT225, that because the distance from valve to carb was so close, we routed the fuel line around the carb and then looped it back over the intake and into the fuel connection.
Is that required on the 250 as well? I hate the thought of running un-filtered fuel into my carb...
#142767 - 09/03/18 04:32 PM Re: XT250 fuel filter [Re: Qwazert]
Reggie Offline
The small in line filters can be fitted but rather than use the straight type you'll find it's easier to use the type that enters from the top and exits the side at 90 deg.
#142787 - 09/04/18 08:35 PM Re: XT250 fuel filter [Re: Qwazert]
Either version works. A 90 deg filter is easier. I couldn't find one locally so I used and straight filter and looped the fuel line around the hose between the air box and carb. Having had issues with water in fuel before, doing the filter like that also has the benefit of having the see-through filter as the lowest point so the water will collect and be visible there.
#142790 - 09/04/18 11:17 PM Re: XT250 fuel filter [Re: peejman]
Qwazert Offline
Yeah...I figured that it would probably need to be done that way if I can't find a 90 type.
Edited by Qwazert (09/04/18 11:18 PM)
0 registered (), 40 Guests and 1 Spider online.
Muniac 5717
Az4x4 4217
peejman 3196
Paul49 1715
JerryH 1516
5298 Members
15825 Topics
5298 Registered Users
