Page 2 of 2 < 1 2
#142440 - 08/06/18 02:02 PM Re: Exhaust bolt broken in head\cam stuck [Re: Rocky Baker]
Loc: High Peak, UK
Brilliant, that sounds like a very fine bit of TIG welding by a very skilled operator.
I was considering fitting copper greased steel studs with brass nuts but I'll wait until the exhaust needs to come off for a very good reason.
#142441 - 08/06/18 02:36 PM Re: Exhaust bolt broken in head\cam stuck [Re: Rocky Baker]
We've had to do that on occasion for aircraft parts. Sometimes just hitting the stud with the arc will cause it to shrink enough to break loose. I hadn't thought about a machinist doing the welding as they're separate jobs here. Good work for sure.
#142495 - 08/10/18 03:45 AM Re: Exhaust bolt broken in head\cam stuck [Re: Muniac]
Rocky Baker Offline
Loc: Timmins, Ontario
Thanks Muniac for taking care of this site and thanks Shawn C for the step by step timing chain disassembly guide.
You are a life saver!
I just finished rebuilding my 1992 Xt225 and the darn thing just would start. I would turn over, it had compression, spark, gas, air....and the thing just would just get a slight sputter sometimes. Considering the year and te rough condition of the bike, I started thinking the purchase of the bike and the time and money put into rebuilding it was a total waste. The fact that it sputtered sometimes kept me going so I was thinking maybe it was a timing issue.
So I drained the oil and reopened the alternator cover. Not being a mechanic, I used your step by step guide to get to the bottom timing chain sprocket and there it was! The chain wasn't even on the sprocket! I then reinstalled everything like you wrote making sure all the timing notches were lined up. Closed everything up, threw some new oil in there and she started right up!!
I have litterally spent most of my spare time all summer working on this bike and your write up helped make it all worth it. Big thanks from this guy who now has a street legal Serow with a newly rebuilt engine and carb for a total of 850$ CAD. I'd say that's a pretty good bargain. Tomorow is break-in time!! &#127949;&#128515;&#128515;
Keep it simple
#142496 - 08/10/18 12:08 PM Re: Exhaust bolt broken in head\cam stuck [Re: Rocky Baker]
Glad you got it fixed, and you're really lucky. The valves must have been closed when you put the head back together. If they'd been open, the piston would have whacked and bent them when you tried to start it.
Next time, rotate the engine by hand with the valve covers off and verify everything is moving like it should before trying to start it.
Did you confirm oil flow to the head via the bleed bolt?
#142501 - 08/10/18 03:28 PM Re: Exhaust bolt broken in head\cam stuck [Re: Rocky Baker]
Muniac Online   content
Always glad to hear the site is helping riders out with repairs. My thanks to those taking the time to contribute valuable content here for others to benefit from. As they say in this business, "Content is king!" Enjoy your bike and ride safely.
#142508 - 08/11/18 02:11 AM Re: Exhaust bolt broken in head\cam stuck [Re: peejman]
Rocky Baker Offline
I did and the pressure must be good because I'm still cleaning some of the oil that spewed out haha. Thanks for the advice on the head. I will definitely be doing that next time, if there is a next time with this bike haha. How long does a new top end last if I'm not a crazy rider and do regular oil changes?
Keep it simple
#142509 - 08/11/18 02:15 AM Re: Exhaust bolt broken in head\cam stuck [Re: Muniac]
Rocky Baker Offline
Now that I have the bike functioning properly, I do plan on slowly adding little things here and there. Everything different I do, I plan on posting here for sure, mostly concentrating on really low budget DIY type of things. I Bought some hardware recently which I believe should help me make a decent windscreen for about 20$. That will be the first thing a contribute but I hope there is much more to come haha
Keep it simple
#142514 - 08/11/18 03:53 PM Re: Exhaust bolt broken in head\cam stuck [Re: Rocky Baker]
Thanks in advance for any project contributions you'll make. Enjoy your bike and be safe.
#142551 - 08/15/18 02:44 AM Re: Exhaust bolt broken in head\cam stuck [Re: Rocky Baker]
Rocky Baker Offline
For anyone who is wondering, I am now 250km into my break in. I did an oil change at 25km and another at 100km. I then started giving a little more throttle during acceleration and I was very satisfied with the results.
As of yesterday I was at about 200km post-rebuild and the engine started running really rough. Burping, gargling, having trouble idling and having no top end power whatsoever, could barely reach 80kph, forget about sustaining it. I then remembered someone saying that in the initial stages of rebuild, it's a good idea to check the valve clearances and adjust as needed. It turns out the intake valve had closed right up completely in the first 200km, giving me no compression (40 psi). I reopened the intake valve and VOILA, whole new machine all over again.
She now has plenty of low end torque and high end power to spare. I Could easily sustain 100kph but did not want to push it farther or hold it there more then 15-20 seconds as it is still quite early in the break-in. I know it's my first real motorcycle, but it's quite impressive what these little machines are capable of when they're in good running order. I now feel confident riding it on local highways (90kph) which is what the plan was from day 1. A fantastic trail bike which is also a good comuter and highway capable!
Serows rule!
Keep it simple
#142558 - 08/15/18 01:10 PM Re: Exhaust bolt broken in head\cam stuck [Re: Rocky Baker]
Glad you're happy with it!
Page 2 of 2 < 1 2
Muniac 5607
Az4x4 4130
peejman 3046
Paul49 1647
JerryH 1511
5226 Members
15692 Topics
5226 Registered Users
24 25 26 27 28
