Page 2 of 6 < 1 2 3 4 5 6 >
#142459 - 08/08/18 01:32 AM Re: Carb problems [Re: jesscody]
jesscody Offline
Loc: montana
Well I am still waiting on the rubber boot the carb goes into and was wanting get a rebuild kit for the carb too but rhey changed from 2000-2001. The bike is labeled as '01 but when I look at pics of the kits on Ebay the older one resembles the float needle more so than the newer kit unless they are using some incorrect photo?
#142461 - 08/08/18 12:01 PM Re: Carb problems [Re: jesscody]
I wouldn't put too much stock in pictures on ebay. I also am not aware of any differences in the carb, so I don't know why there would be different rebuild kits. Could be that the parts are interchangeable but they look a little different. There are 3(?) styles of main jet that are interchangeable... small hex, large hex, and round all will fit and work fine. That's the only thing I can think of.
#142462 - 08/08/18 12:45 PM Re: Carb problems [Re: jesscody]
jesscody Offline
Loc: montana
Ok, thanks. When i droppes the skid plate to change oil I found an o ring that I am sure I must have dropped from the carb. Its a driwd out and broken one so thats why I want a kit.
#142465 - 08/08/18 07:24 PM Re: Carb problems [Re: jesscody]
Muniac Online   content
The oil drain plug contains an O-ring. Also the cover for the fine mesh oil filter contains two O-rings.
#142472 - 08/09/18 12:57 AM Re: Carb problems [Re: jesscody]
jesscody Offline
Loc: montana
This oring was more carb sized and was there before i pulled the plug.
#142484 - 08/09/18 12:57 PM Re: Carb problems [Re: jesscody]
Valve cover or starter o-ring? There's also an o-ring between the intake and cylinder.
#142488 - 08/09/18 06:24 PM Re: Carb problems [Re: jesscody]
jesscody Offline
Loc: montana
I sm sure i dropped it from the carb. Its like 1/4" big, so really small.
#142502 - 08/10/18 06:21 PM Re: Carb problems [Re: jesscody]
jesscody Offline
Loc: montana
Well I was chasing ghost. Took rhe carb apart and no orings missing
#142505 - 08/10/18 07:06 PM Re: Carb problems [Re: jesscody]
1/4" diameter could be the o-ring that covers the bottom bolt in the oil filter cover.
#142506 - 08/10/18 07:44 PM Re: Carb problems [Re: jesscody]
That's what I was thinking too. If that O-ring isn't in there you'll have oil flow issues. Best check that IMMEDIATELY! Very easy to remove that cover for inspection. Two hex head bolts and a 3rd socket head (Allen key) cap screw (O-ring is on that one). Good luck!
Muniac 5607
Az4x4 4130
peejman 3046
Paul49 1647
JerryH 1511
5226 Members
15692 Topics
5226 Registered Users
24 25 26 27 28
