Rear rim xt225
#141908
06/16/18 12:21 AM
BCGUNCOLL
Posts: 17 |
I'm coming to y'all with a question I'm not sure about. Will a 250 rear rim fit the xt 225??
Mtnmanmongo. 2005 XT 225
Re: Rear rim xt225
[Re: BCGUNCOLL]
#141910
06/16/18 12:16 PM
Not sure. The hub is different since the 250 has a rear disk brake. A quick way to see if it's close would be to measure the width of each hub and see if they're different.
Re: Rear rim xt225
[Re: BCGUNCOLL]
#141911
06/16/18 05:04 PM
You're asking about the rim. I'm assuming you'll be keeping the stock hub? The XT225 has 36 spokes in 4 groups (different styles) of 9 spokes each. I'm also thinking the XT225's rim is "dished" slightly. So you'll need to check the number of spoke holes in the 250 rim. Needs to be 36. Also that the spoke nipple holes will accommodate the XT225 spokes. They have limited adjustment too. If the profile on the rim holes is different that may prevent mounting spokes and tensioning them properly. If you're looking to beef up the XT225's rim there are other options. Excel makes good rims. A company called Buchanan's Spoke & Rim, Inc. can create a solid rear wheel for you. Better spokes, quality rim and a stronger lacing pattern. And off the stock XT225 hub. Keep in mind the XT225 hub is a molded metal process and somewhat soft. Causing spoke holes to elongate. The shoulder on those spokes is also sharp as opposed to a straighter pull. Further weakening the build. Butted spokes can help there. Good luck and I hope this helps.
Re: Rear rim xt225
[Re: BCGUNCOLL]
#141915
06/17/18 02:01 AM
BCGUNCOLL
Posts: 17 |
All I'm looking to do is have a spare rim/tire ready to slap on my xt225. Have a all season tire on one rim, and a knobby on the other. Just flip flop em whenever I wanna ride different ground. Will the 250 rim/tire fit the xt225?
Re: Rear rim xt225
[Re: BCGUNCOLL]
#141916
06/17/18 02:37 AM
OK, I understand. Even if it did fit what would you plan to do about a rear brake? The XT250 has a rear disc brake. The XT225 has a drum brake integrated into the rear hub. Why not scour some of the motorcycle salvage yards and get a stock XT225 rear rim, spokes and hub? You can place an ad here for one too. Good luck with it.
