Holier than thou Exhaust #141612 05/11/18 01:42 PM
Paul49 Offline OP
Out yesterday up in t'hills, methinks, exhaust sounds noisier than usual.
Took it off today, seemed fine if a little rusty on parts we don't see. Got the electric wire brush on it & oh no, holes appearing when I cleared the rust.
I remember Reggie getting a Delkevicuk one, I think the 350mm version, I couldn't find his post on it. So I ordered one anyway based on my failing memory.
https://www.ebay.co.uk/itm/292333594338
Re: Holier than thou Exhaust [Re: Paul49] #141613 05/11/18 02:03 PM
Wow, that's a huge silencer for such a small bike. Do you have to adhere to OEM noise requirements?
Re: Holier than thou Exhaust [Re: peejman] #141617 05/11/18 02:20 PM
Paul49 Offline OP
Ha It's the small one, similar size to the original, they also do a 450mm version, by 'eck that's long, and a 225mm race? version. Dunno what they'd be racing. My MOT tester wouldn't like that one.
On the + side, it's 3.5 lbs lighter than original.
Re: Holier than thou Exhaust [Re: Paul49] #141643 05/13/18 01:05 AM
3.5 lbs is a pretty good weight reduction.
Re: Holier than thou Exhaust [Re: Paul49] #141645 05/13/18 06:40 AM
Paul49 Offline OP
Aye m8, if it turns out the advertised weight of 1.9kg, the stock one I weighed is 3.5kg. I converted it for you folks being stuck in a time warp ha laugh We're used to this funny weight thing now.
It's on its way I got a tracking number, I rec'n it's on the back of a snail. I could have gone & got it, only 30 miles away, it's now on its way to the courier depot which is 30 miles in the opposite direction, then it'll spend a day on a shelf before a courier takes it for a tour of Cheshire.
Re: Holier than thou Exhaust [Re: Paul49] #141646 05/13/18 01:24 PM
BigSm0ke Offline
If I get an excuse to get that I will. Would this work out fine with stock jetting / carb setup, or too much flow?
The race was definitely underway. I had witnessed the start, I was sure of that much. But what now? What comes next?
Re: Holier than thou Exhaust [Re: Paul49] #141647 05/13/18 02:53 PM
We found exhaust systems less restrictive than the OEM version caused a very slight leaning of the mixture. Also a small increase in noticeable power. Easily compensated for by increasing the main jet one size. A wait and see situation, however. Mod your exhaust, run the bike for a while and see how it performs. Adjust if/as required.
Re: Holier than thou Exhaust [Re: Paul49] #141650 05/13/18 05:12 PM
Paul49 Offline OP
I can't remember what Reggie said when he fitted the same exhaust, if he had to re-jet or not.
I know when I fitted a K&N air filter to my Brazil XT225 it totally screwed up the fuelling, died above half throttle. I had two goes at re-jetting then it got stolen before I got it right.
I'll let y'all know when i get it fitted. Not here yet.
Re: Holier than thou Exhaust [Re: Paul49] #141676 05/15/18 07:21 AM
Paul49 Offline OP
The exhaust fitted fine at front end to the down pipe & lined up fine with the bolt hole. At the back it came with a spacer & bolt, these were not long enough for it to clear the mudguard, needed another 6mm spacer & longer bolt. All fitted up fine now. Fired up & what a nice sound, not too loud but deep bark Brrrum Brrrum, very nice. Overall, better looking, much lighter, better sound & cheaper than oem.
Just needs a road test now to check fuelling.
Re: Holier than thou Exhaust [Re: Paul49] #141737 05/25/18 07:28 PM
B
Bush Pig Offline
B
Hello,
From out of the blue.
I am a first time motorcycle owner with a very old machine (1987)
that is in need of a new header pipe.
The one on the machine is mild steel.
I am going to have one made up.
Should I stick with mild or go stainless?
Bush Pig
Muniac 6,619
Az4x4 5,071
peejman 4,160
Paul49 2,113
Topics16,834
Posts151,323
Members6,009
6009 Registered Users
