#140663 - 02/12/18 10:01 PM Adjustable clutch/brake levers?
Wallhopper Offline
Loc: Dorset ,UK
Hi Everyone.
Just wondering if anyone knows if there are adjustable levers available for the xt225?
I want to bring the levers in closer to the handlebar as the clutch/brake is nearly on my maximum reach. I have already bought levers with more of a dog leg which has helped.
Was thinking of maybe heating and bending the levers in, but I'm thinking this would make the levers weak. Has anyone done this with success?
Or has anyone modified to a different lever?
Thanks in adavance
#140666 - 02/12/18 11:01 PM Re: Adjustable clutch/brake levers? [Re: Wallhopper]
patuca Offline
Loc: Cranbrook BC Canada
A quick trick is to slacken the cable so the lever is slack then cut a thin spacer from a piece of plastic tubing (gas line etc but hard plastic is better) say 4 or 5mm thick.
Slice one side of the spacer (washer) so it fits over the cable when it's exposed between the perch and the lever. Trim the washer thickness so when the brake is adjusted the washer will hold the lever away from the perch and the lever will be closer. Be careful you still have enough lever motion when you really need to squeeze.
I've seen some mods where the lever or the perch is drilled for an adjustable set screw that holds the lever face away from the perch and will keep the lever from closing completely.
There are adjustable levers but last time I looked they were rare it might take some searching.
Good levers are malleable and will bend cold in a vise but it's an expensive experiment on new levers. It might be worth trying on some used ones but only on the long part of the handle. Heating alloy to bend it is not a good idea...
Just some shots....
patuca
Edited by patuca (02/12/18 11:03 PM)
#140673 - 02/13/18 12:58 PM Re: Adjustable clutch/brake levers? [Re: Wallhopper]
The factory levers are adjustable, there's an adjustment screw near the pivot. There's a 2nd adjustment for the clutch cable about half way along the length of it, typically near the carb.
In my experience, moving the levers in close to the bar tends to reduce the travel to an extent that affects function. Meaning... if you set the clutch lever close in to the bar, you won't be able to fully disengage the clutch when you squeeze the lever all the way in.
Similarly with the brake, if the lever is close to the bar, you'll limit your braking force and won't be able to apply maximum braking. Given how crappy the stock front brake is already, that's a pretty scary concept.
#140677 - 02/13/18 04:33 PM Re: Adjustable clutch/brake levers? [Re: Wallhopper]
Loc: Atlanta,GA
^ Those adjustments only adjust the freeplay, they don't actually move the levers closer to the handlebar when they are disengaged.
#140680 - 02/13/18 05:15 PM Re: Adjustable clutch/brake levers? [Re: Wallhopper]
Loc: Atlanta,GA
I saw one on Amazon. Adjustable clutch lever, from Motion Pro part# 14-0405. The only problem is, in the picture they show 4 levers, only one of which is adjustable. May be worth looking in to, maybe send in your question. The companion brake lever is part# 14-0506. Sorry I cant figure out how to put a link up to it.
#140703 - 02/14/18 05:27 PM Re: Adjustable clutch/brake levers? [Re: Wallhopper]
Wallhopper Offline
Loc: Dorset ,UK
Hi,
Thanks for the replies, I'm planning on giving your advise a go at the weekend, and I'll check out the motion pro levers. Hopefully there available in the UK.
0 registered (), 57 Guests and 0 Spiders online.
Reggie 11639
Muniac 5581
Az4x4 4119
peejman 3021
Paul49 1640
JerryH 1509
5212 Members
15667 Topics
5212 Registered Users
1 2 3 4 5
27 28 29 30 31
