Mixture screw adjustment
#139659
12/10/17 11:10 PM
Craig1
Posts: 48 |
What is the easiest way to adjust the fuel mixture screw on my 92 XT225 when the engine is hot? I'm finding it hard to work a small screwdriver in there without touching something very hot. Are extended mixture screws available? I bought one of these, but it did not fit.
https://www.ebay.com/itm/Adjust-Fuel-Mixture-Screw-FCR-Carbs-Air-Carburetor-For-Yamaha-XT225-XT250-TW200/282666916002?hash=item41d042d8a2:g:thQAAOSwTUVZuO2x&vxp=mtr
Craig
Re: Mixture screw adjustment
[Re: Craig1]
#139664
12/10/17 11:53 PM
You will have to find the size screwdriver that works best. I too think this is the best way to find the proper a/f adjustment, as all bikes are a little different.
[Re: Craig1]
#139671
12/11/17 02:46 PM
Posts: 4,163 |
Wear gloves.
The mixture screw is a "set it and forget it" thing. It shouldn't require routine fiddling.
[Re: Craig1]
#139717
12/15/17 03:06 AM
Qwazert
Posts: 326 |
I made one out of a 1" circle of 1/4" rubber. I cut it out with a hole saw and then drove a flat-blade bit into the center hole. You could set it when cold....2½ - 3 turns out from seated.
[Re: Craig1]
#139718
12/15/17 09:41 AM
You could put the screw bit in a 1/4" socket.
[Re: Craig1]
#139774
12/21/17 12:40 AM
garywi
Posts: 533 |
No XTs at the moment..
Members6,014
