#138751 - 10/12/17 10:05 PM Missing carb hoses
Craig1 Offline
Loc: GlenAllen, VA
Got my new to me 92 XT225 this past Saturday. I took it out for a quick ride and made sure it was running well, then tore it down. Ordered some parts, (new petcock, air and oil filter, clutch lever, fork boots).
One thing that is bothering me is there are two ports on the carburetor with no hoses attached.
One very small black, downward, facing fitting on the left side of the carburetor and a larger, downward facing metal fitting on the right side.
What should these connect to?
#138752 - 10/12/17 10:48 PM Re: Missing carb hoses [Re: Craig1]
Loc: Atlanta,GA
The one on the left is a drain tube connected to the float bowl drain, other end doesn't connect to anything. The one on the right is a carb vent tube, the other end doesn't connect to anything.
#138755 - 10/13/17 02:02 PM Re: Missing carb hoses [Re: Craig1]
Yep. Just get most any sort of hose the right diameter and run the end down through the gap between the back of the case and the swingarm.
#138760 - 10/14/17 02:24 AM Re: Missing carb hoses [Re: Craig1]
Craig1 Offline
Loc: GlenAllen, VA
I'm a little confused. Are you telling me to connect a tube to the fitting on the right side of the carb and also a hose on that tiny black fitting on the left side, and run them both by the swing arm?
Also, is there a factory service manual available for these bikes?
#138762 - 10/14/17 02:58 PM Re: Missing carb hoses [Re: Craig1]
Loc: Heber/Overgaard, AZ
Originally Posted By: Craig1
..is there a factory service manual available for these bikes?..
Do a Google search for '1992 XT225 Factory Service Manual.' You'll find there's lots of options for acquiring the manual you're looking for..
#138763 - 10/14/17 11:07 PM Re: Missing carb hoses [Re: Craig1]
Loc: Atlanta,GA
That is correct. If you cant find a small enough tube to connect to the float bowl (the one on the left), I wouldn't worry about it, it is not that important. That other one on the right, it might be a good idea to put one on that, to insure no debris entering into the carb from there.
0 registered (), 31 Guests and 2 Spiders online.
Reggie 11583
Muniac 5471
Az4x4 4074
peejman 2914
kris 2365
Paul49 1606
JerryH 1508
5158 Members
15529 Topics
Vegas Matt, cavedweller, Nick Stone, Bobbyh83, W Calvin
5158 Registered Users
September
