#136565 - 05/04/17 08:44 PM Grip glue
Qwazert Offline
Loc: BC Canada
I bought a new set of pillow-top grips a few weeks back, and I'm having a heckuva time getting them to stick!!!
In the past, I've used dish soap with amazing success...didn't work.
Others suggested hair spray...didn't hold (pardon the pun).
My next option is some spray adhesive.
What do others use when you don't have grip glue?
http://dr650rider.blogspot.ca/
#136570 - 05/05/17 01:57 PM Re: Grip glue [Re: Qwazert]
I had the same problem, the clutch side grip wouldn't stick the heavy knurling on the bar. Grip glue solved it. The local shop had a small tube for something like $2. I'd think most any general epoxy rated for steel and rubber would work. Else there's always safety wire.
#136571 - 05/05/17 02:17 PM Re: Grip glue [Re: Qwazert]
Qwazert Offline
Loc: BC Canada
Well the spray adhesive made a mess of things....luckily I was able to clean it ALL off with solvent!
Tried some rubber cement and that seemed to do the trick, then I watched a video on how to PROPERLY use tie-wire on handgrips, so I gave that a whirl.
Now it looks like these babies aren't coming off until I tell them to!
#136638 - 05/09/17 07:06 PM Re: Grip glue [Re: Qwazert]
Selden Offline
Loc: GA
Use hair mousse, preferably the "extra hold" flavor. The grip will slide and adjust easily when wet, but after 24 hours the mousse dries and the grip is securely stuck but, since it's water soluble, not too difficult to unstick if the need arises.
#137551 - 07/24/17 01:21 AM Re: Grip glue [Re: Qwazert]
Bandit Offline
Loc: Rochester,New York
I put a set of Pillow Tops on today and used hair spray.The grips would not have slid on without a lubricant as they were such a tight fit.If the hair spray loosens I will just use a grip glue.I have had hair spray stay put and not stay put on different bikes.
1 registered (BigSm0ke), 18 Guests and 1 Spider online.
Reggie 11534
Muniac 5276
Az4x4 4049
peejman 2693
kris 2365
Paul49 1543
JerryH 1508
5058 Members
15316 Topics
USA123, RussBrumit, SilvaBullet, punchy, paxmaster2000
5058 Registered Users
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30
