Page 2 of 2 1 2
Re: Tires [Re: cogitech] #134973 12/01/16 01:03 AM
alexd Offline OP
I've been told differently.
The example given to me which could cause problems, was a Kenda 750 Trackmaster II (not 760) if I recall correctly, in 110/100 size, not 100/100. I want the extra width.
Anyway, I'll look further into this. Thanks for your advice!
Re: Tires [Re: alexd] #134975 12/01/16 02:17 AM
C
cogitech Offline
C
Best of luck. There are lots of good tires out there if you let yourself wiggle a bit on the precise dimensions. I can assure you that you won't have any fit/clearance/gearing issues with a 100/100.
I'd rather have a slightly narrower tire that is up to the task than a perfectly sized one that can't rid itself of mud or hook up in sand. smile
Re: Tires [Re: cogitech] #134977 12/01/16 06:33 AM
alexd Offline OP
Thanks again...but as I said before, mud and sand are not my concern.
Re: Tires [Re: alexd] #134981 12/01/16 01:05 PM
I've got the Shinko 241 which is a trials tire pattern using DOT applicable rubber. So far (~2500 miles), they're great on/off road. They don't like deep mud, but seem to stick quite well everywhere else (loose/hard dirt, gravel, leaves/pine needles, ...) I've not ridden in sand. They also seem to have a minimal footprint, meaning they don't tear up the ground like a really aggressive knobby.
http://www.shinkotireusa.com/tire/sr-241-series
And they're fairly cheap, so if you don't like them, you're not out $250.
Re: Tires [Re: peejman] #134982 12/01/16 02:31 PM
Selden Offline
What sizes are you using?
Re: Tires [Re: alexd] #134983 12/01/16 03:59 PM
C
cogitech Offline
C
Sorry. I misinterpreted "not specifically designed for either sand or mud", as being not specifically designed for "one or the other". I assumed you wanted something that is good for all terrain.
Re: Tires [Re: Selden] #134995 12/01/16 07:40 PM
Best I recall... 3.0x21 and 3.5x18. The 4.0x18 rear should fit, but I didn't want the larger OD since I've got a 16T front sprocket.
Re: Tires [Re: peejman] #135014 12/02/16 06:16 PM
Selden Offline
Thanks. I'm also running a 16T front sprocket, so same thinking applies.
Not that I'm anywhere near a tire change, but do people usually put in new tubes with new tires, or keep the old ones, if in good shape and never punctured? I haven't owned a bike with inner tubes since ~1983.
Re: Tires [Re: alexd] #135018 12/03/16 02:55 PM
Jerry XT Offline
I would highly suspect 25 year old rubber....
especially if I put my life on it
but, to answer your question, I don't know
oh, I read your post wrong, sorry / delete!
JJ 2007 XT225
Re: Tires [Re: Selden] #135019 12/03/16 03:03 PM
False economy not to fit a new H/D tube & rim tape while the tyres off. They're cheap enough.
Page 2 of 2 1 2
0 registered members (), 45 guests, and 0 spiders.
Muniac 6,148
Az4x4 4,763
peejman 3,639
Paul49 1,912
JerryH 1,720
Topics16,320
Posts146,595
Members5,591
TXrider, DigitalNomad, fillypeeno, Neil Cooper, Jeanette
5591 Registered Users
