Re: What did You do to Your Duel Sport today?
[Re: Ben]
#112302
06/01/13 11:42 PM
vic
Posts: 602 |
just replaced my factory handlebars with new ones today. went with the renthal bradshaw/emig set. i really like them they feel much better than the orginals. one more new addition to the little xt. when will the upgrades ever stop lol.
take it day by day and have fun 06xt225 z1mod,127.5/42.5 jets,3turnsout,16tfront,k&n oil filter uni air filter.00 and 01 TT-R250
[Re: vic]
#112313
06/02/13 06:41 AM
Posts: 2,112 |
Great mod vic,
I went with the Renthals also 735's 5,1/2" Trials bars.
[Re: Paul49]
#112314
06/02/13 08:19 AM
vic
Posts: 602 |
thnx ill try to get a pic up. but ill have to say again how much bether they are than factory. should have done this one long ago
[Re: vic]
#112542
06/09/13 06:32 AM
Ben
Posts: 870 |
Had to lean it over on its side to replace the sump plug washer, I know you should replace each oil change, but I had re-used it about 6 times and it was leaking, so without dropping the oil I replaced it. Then decided to drop the oil in its bigger barn companion, used an old enamel bowl I had lying around, which had a hole in it, Oil everywhere!
2007 serow 250 from new, now gone to a new home. 2022 Gasgas EC300
[Re: Ben]
#112550
06/09/13 08:01 PM
Posts: 11,645 |
Hi Ben,
I can imagine the choice language!
[Re: Reggie]
#112578
06/10/13 03:00 PM
Posts: 6,615 |
Replaced front tire tube and installed new disk brake pads (front).
#112609
06/11/13 01:02 AM
MikeC
Gold Member
Gold Member
Posts: 730 |
I installed a Turn Signal Beeper today. I don't know if it's because I'm over 50 or what, but I find myself leaving the blinkers on way too often! These really work, they are are inexpensive ($5.49 for the smallest beeper and a bridge rectifier at Radio Shack), and are pretty easy to install.
[Re: MikeC]
#112681
06/12/13 12:57 AM
American Greenz
Posts: 272 |
Vic,
I see you have a 16T front gear. What are your results with this upgrade? Did you have to install a larger chain? Which brand of gear did you install?
I believe that would give you increased top speed.
thanks, John
2007 XT225:Z1,Coleman Seat,M-Wave on Immix Rack,Signal Beeper,127.5m/42.5p,Uni filter, Iridium Plug, Turbo City Windscreen
[Re: American Greenz]
#112689
06/12/13 03:16 AM
Vic,
thanks, John A 16T front sprocket can usually just fit with the stock chain. The advantage is for road people that prefer less RPM at their usual cruising speed. The trade-off is less power against wind and hills. It's not unusual for the stock gearing on the same bike to go ultimately faster in top speed, depending upon the conditions. This is true on many bikes (and cars with geared up rear-end gears). Alexd
[Re: alexd]
#112815
06/15/13 01:19 AM
vic
Posts: 602 |
it does give me less rpm and a little more top end. gas milage stayed about same. and I ordered a sunstar 16t front
