Page 2 of 4 1 2 3 4
Re: Need Help Now [Re: racerb] #105587 12/07/12 05:17 AM
T
tuna Offline OP
T
Is this it? Do you just mean a 3/32 left hand drill bit?
http://www.fastenal.com/web/products/detail.ex?sku=3156048
If so,the closest store to me says out of stock on invetory check.But I can find somewhere, thank you very much, Craig
Craig/Tuna
Re: Need Help Now [Re: tuna] #105603 12/07/12 04:26 PM
T
tuna Offline OP
T
Talked with Fastenal and this is what I ordered.
http://www.fastenal.com/web/products/detail.ex?sku=0356147
Thought I'd just add this, Talked to Jessie and his wife at Keintech, couldn't be 2 nicer people. Jessie also knows alot of tricks on the XT225 and has special ways of taking care of problems, I highly reccommend them.
http://kientech.com/
Craig/Tuna
Re: Need Help Now [Re: racerb] #105637 12/08/12 01:59 AM
R
racerb Offline
R
yes that is a lft handed drill. The idea is to run a at very slow speed in reverse so as to cause the drill to dig into the screww head and drive out the screw. it is not to actually drill a hole into or through the screw. I have used this very method to remove head damaged screws many times and like I said, my first xt had the same problem yours had and it worked perfectly. You can even practice on some other pieces with screws to get the hang of light pressure and slow speed and see how it works to gain confidence before you perform on you critical application.
Dave Brown
Re: Need Help Now [Re: racerb] #105638 12/08/12 02:14 AM
R
racerb Offline
R
I should point out this method is for a non tight screw such as the mixture adjusting screw. if the screw is tightened down or thread damaged then it will mearly put a hole in the head, which is NOT desirable. Unless it is crossthreaded in the hole this will work. If the screw slott was ripped out because the screw was cross threaded into the hole or bottomed out and tightened then getting the screw out is the least of your problems. since your bike idles reasonably ok now I doubt it is tight or on it's seat. But, since you said you were new at this i felt i should give a bit of disclaimer.
Dave Brown
Re: Need Help Now [Re: tuna] #105639 12/08/12 02:42 AM
alexd Offline
Absolutely!
Re: Need Help Now [Re: alexd] #105791 12/11/12 06:48 PM
T
tuna Offline OP
T
Just thought I'd post a update. Went to the local Yamaha shop to order a new Pilot Screw set and was told it would take 10 days, forget it, I try to not do bussiness with them for that reason, god they piss me off! Called Jessie at Kientech and its in the mail today, cost a little more but much better and I'll get it in a few days.Still waiting for my LH drill bit as mentioned above, hope it's here today. Don't want to start till I have everything. I now have the time but no parts. Will post updates when I have something to post, hopefully w/pictures.
Craig/Tuna
Re: Need Help Now [Re: tuna] #105801 12/11/12 09:53 PM
150ron Offline
Kientech is great stuff for sure, i just put a extended fuel screw on my bike, and it makes adjusting the fuel/air screw 10x easier.
Stock XT225
Re: Need Help Now [Re: 150ron] #105914 12/14/12 05:42 AM
P
porklunch Offline
P
what about a dremel and one of those bits and cut a slot groove into it
[censored] cock lickers
Re: Need Help Now [Re: porklunch] #105921 12/14/12 02:25 PM
T
tuna Offline OP
T
Being recessed like it is you can't get in there with a Dremel. LH bit is getting here today, about fricken time.Got mail order is slow.
Craig/Tuna
Re: Need Help Now [Re: tuna] #105925 12/14/12 03:03 PM
kris Offline
i have a kintech it makes fine tuning very easy but be carefull not to burn your hand on exhaust
kris............ give me more mud
Page 2 of 4 1 2 3 4
0 registered members (), 45 guests, and 0 spiders.
Muniac 6,148
Az4x4 4,763
peejman 3,639
Paul49 1,912
JerryH 1,720
Topics16,320
Posts146,595
Members5,591
TXrider, DigitalNomad, fillypeeno, Neil Cooper, Jeanette
5591 Registered Users
