Rating: 5
Page 1 of 7 1 2 3 4 5 6 7
DIY XT-225 valve adjust #10228 07/08/06 02:55 AM
K
klm4755 Offline OP
K
Enclosed is a step by step process for conducting a valve adjustment on a Yamaha XT-225. The Bike in the photoís is my 2005 model. Make sure the bike is in neutral, fuel shut off, and is cold (not ran in the past ~8 hours). Please feel free to add to the steps with you tips, tricks, and tribal knowledge for the benefit of all!
Remove side covers, Phillips head screw driver required.
Remove seat. 10 mm socket + rachet works best
Looks like this now
tank side covers next, 10 mm + socket with 4" extension, pull away from tank to release attach stake
covers off
Unhook fuel line from tank
use rag to catch dripping gas
Tank bolt next 10mm size
Keith
Re: DIY XT-225 valve adjust #10229 07/08/06 02:55 AM
K
klm4755 Offline OP
K
this bracket may lift with the tank. That is ok
If lifted
Tank attach parts
tank with attach parts off
Make sure tank valve is not supporting tank weight, let overhang like this
Need to remove this plug
need to remove this plug also
Almost ready to remove valve cover, need allen socket head
Keith
Re: DIY XT-225 valve adjust #10230 07/08/06 02:56 AM
K
klm4755 Offline OP
K
Start on right side of bike, 5x bolts, all of same size (diameter and grip length), so ok to mix up. Front cover houses exhaust valve, rear cover houses intake valve. Trying first bolt on exhaust side. 3x on exhaust, 2x on intake
First bolt on intake side.
not enough clearance to use socket setup for other 3x bolts, so must use allen key.
exhaust cover off
intake cover off
All engine access parts off, will inspect later
Intake valve closeup
Attach 17mm socket to this bolt, use small 4" extension
Keith
Re: DIY XT-225 valve adjust #10231 07/08/06 02:57 AM
K
klm4755 Offline OP
K
Like this, rotate Anti-clockwise while looking in the view port hole
look here
these are the 3 radial groves on the flywheel, the one in the middle is top dead center (TDC), however a four stroke engine may read bottom dead center ( Iím not that sure about this statement). However, it is not important. What is important is to check the exhaust gap while you have the center groove visible. If you can get a .003" feeler gage in the gap your at TDC. If not rotate the flywheel another 360 degrees anti-clockwise and check the gap. This time it will be there. So, you have a 50/50 chance of getting it right the first time. By the way donít use the rachet function on your tool. Once you see the flywheel notches, just spin your tool one full revolution to see notches again!
Need specifications for valve gaps. Do exhaust first .006 to .007 inch
Need right feeler gages
Exhaust gap
Too big needs adjustment, can easily fit .007 inch gage
Need valve tool. Some folks use needle nose. I found this tool make job a lot easier. Use 3mm side. It will hold the valve adjust bolt steady while you tighten the valve lock bolt.
[ July 08, 2006: Message edited by: klm4755 ]
Keith
Re: DIY XT-225 valve adjust #10232 07/08/06 02:57 AM
K
klm4755 Offline OP
K
loosen lock bolt with 10mm open end socket, adjust valve with tool, check with feeler gage. One gap is correct, Hold valve steady with valve tool and tighten lock nut. Donít let valve spin with locknut. This is where the tool is handy!
Need to tighten lockbolt with torque wrench 10 ft*lbs, but torque wrench will not fit so.....
Use this!
Torque wrench in action
feeler gages for intake. Gap between .002-.004 inch Only had a .002 and .003 inch. Will work.
Gap too big, need to adjust
adjusting intake valve
tighten intake
Keith
Re: DIY XT-225 valve adjust #10233 07/08/06 02:58 AM
K
klm4755 Offline OP
K
torque locknut
torque wrench on intake valve
Inspect exhaust valve cover, seals look good
inspect intake valve cover, OK too
Clean valve cover interface
put covers back on
flywheel cover back on
torque the 2x right side allen cover screws intake and exhaust 7.2 ft*lbs. Other 3x will need to be attached by allen key, no room for torque wrench.
Keith
Re: DIY XT-225 valve adjust #10234 07/08/06 02:59 AM
K
klm4755 Offline OP
K
Other side
seat on
use torque wrench 5 ft*lbs
attach fuel like hook up, side covers, seat
All buttoned up! Ready to test ride. Results -No pings thru any of the throttle/gear ranges.
Keith
Re: DIY XT-225 valve adjust #10235 07/08/06 04:18 AM
Reggie Offline
Hi Chaps,
who needs a Haynes or Clymer workshop manual when we've got KLM?
Well done Good Sir and keep up the fantastic work.
Re: DIY XT-225 valve adjust #10236 07/08/06 06:34 AM
D
Dj7177 Offline
D
Great post,
Just one thing though.
Shouldn't the crank be rotated Anti-Clockwise and NOT Clockwise?
Regards,
Dave
Why pay someone else to make mistakes, I make mistakes for free.
Re: DIY XT-225 valve adjust #10237 07/08/06 07:30 AM
D
danno Offline
D
Want more midrange? close the intake valve sooner. How wider gap(within the spec) will change the duration of cam on the intake. With a compression tester you can see the added pressure(static) You dont need to do the wrench on the crank thing. High gear can be used to bump the engine around. Exhaust open then intake open and close is compression.I still like the ol thumb on the spark plug hole and puchhhh. I think I might be on compression. Once I can obtain a compression tester I will share my results. Really cool step by step. The cam chain (should be able to withstand backwards cranking)but not recommended.
0 registered members (), 29 guests, and 2 spiders.
Muniac 6,010
Az4x4 4,533
peejman 3,434
Paul49 1,859
JerryH 1,550
Topics16,130
Posts144,598
Members5,463
AZrancher22, TamirG, Blueberries, rickrowls, Davide
5463 Registered Users
