Page 4 of 4 1 2 3 4
Re: Air/Fuel mix screw pic? [Re: Wanabecruisen] #100903 08/15/12 10:01 PM
W
Wanabecruisen Offline OP
W
Confused??? I found my old hand held compression tester and ran a check with that. Only gets to about 75psi! Compression is very low but why?
It starts well, idles well(once warm), and runs fine through the lower gears. No smoke at all, no fouling on the plug, etc. Could the valves be so out of adjustment to give these kind of readings?
Old Berzerker
Re: Air/Fuel mix screw pic? [Re: Wanabecruisen] #100904 08/15/12 10:09 PM
alexd Offline
Not likely, without problems starting too.
While you're at it, change your oil as more than usual contamination might be occurring. I recommend Mobil One 10W-40 or 0W-40, automotive types.
Re: Air/Fuel mix screw pic? [Re: alexd] #100905 08/15/12 10:24 PM
W
W
Nevermind. I doubted the accuracy of the old compression tester so I devised a test. I used the known pressure from my air compressor and checked it against the gauge. WAY off. I'm going to toss this tester and build an adapter for my good tester. I'll report back again tomorrow.
Old Berzerker
Re: Air/Fuel mix screw pic? [Re: Wanabecruisen] #100922 08/16/12 06:45 AM
alexd Offline
There are compression tests, and leak-down tests. I believe compression tests are preferential to warmed up engines (and oil).
Re: Air/Fuel mix screw pic? [Re: alexd] #148306 06/24/20 12:56 AM
K
Kenny4 Offline
K
Originally Posted by alexd
Here's another; the plug was pre-drilled, as the owner will be inserting a screw to "grab" the brass and allow pulling the thing straight out.
When you do this, be sure to not drill in too far, which would gouge up the adjustment needle within.
[Linked Image from i1085.photobucket.com]
This is right in the middle of the 3 aluminum openings and facing down to the ground right? Is it part #34-35 on this chart and if so how would you get a drill bit in there without removing the carb? Any vids showing how to do this without removing the carb? Thank
OEM Carb Parts
Here's a vid I found, ( but with the carb removed )
Cap Removal
Kenny4
Re: Air/Fuel mix screw pic? [Re: Wanabecruisen] #148308 06/24/20 11:34 AM
peejman Online Content
Yes, its the brass plug in the boss that faces down. There may be a very small hole in it already. You can loosen the clamps and rotate the carb in place without removing the throttle cables. Rotate it about 45 deg and you can get at the plug to remove it.
[Linked Image from photos.smugmug.com]
Page 4 of 4 1 2 3 4
2 registered members (TheWowJester, Kuato1982), 37 guests, and 3 spiders.
Muniac 6,186
Az4x4 4,860
peejman 3,727
Paul49 1,940
JerryH 1,843
Topics16,409
Posts147,585
Members5,629
TheWowJester, scotsy, ssnead, noidsleft7876, Welsh Gai
5629 Registered Users
