Air/Fuel mix screw pic?
#100450
08/03/12 06:52 PM
Wanabecruisen
Posts: 18 |
I can prolly figure this three turn thing out but was looking for a pic of the carb showing the location of the tamper plug that needs to be drilled out on the XT225. New to the site and still trying to get used to the search function on here. Is it basically in the same location as on the 250?
Old Berzerker
Re: Air/Fuel mix screw pic?
[Re: Wanabecruisen]
#100451
08/03/12 07:05 PM
There are pictures around here somewhere. It's on the bottom part of the carb closest to the engine, between and slightly forward (towards engine) of the front two (of the 4) screws that hold the floatbowl on.
Do NOT confuse it with a close-by brass "dimple" that is visible in one of the holes.
Not all bikes have the anti-tamper plug...
[Re: alexd]
#100474
08/04/12 07:50 AM
Here's one; not all carbs have the hose, which is partially obscuring the pilot jet adjustment needle (the anti-tamper plug has been removed) A small flat-blade screw driver is used to adjust it. Alexd
[Re: alexd]
#100489
08/04/12 07:08 PM
Here's another; the plug was pre-drilled, as the owner will be inserting a screw to "grab" the brass and allow pulling the thing straight out. When you do this, be sure to not drill in too far, which would gouge up the adjustment needle within. Alexd
[Re: alexd]
#100527
08/05/12 11:15 PM
Wanabecruisen
Posts: 18 |
Great! Thanks for the pix
Old Berzerker
[Re: Wanabecruisen]
#100528
08/05/12 11:42 PM
You're welcome.
You might want to take the opportunity to replace the 4 Philips-head screws that hold the float-bowl, with Allen-head types (which won't strip or deform). I forget the metric size (possibly M6) but 12mm or 16mm length is fine, in either black or stainless. Home Depot, Menards, and Lowes should have them.
Alexd (P.S. Look into a fuel line filter such as the mini 1/4" Visufilter, for your next Mod)
[Re: alexd]
#100531
08/06/12 12:43 AM
tkerrigan
Posts: 26 |
One thing that will help on stripping phillips screws on Japanese bikes and other equipment would be to get a set of JIS (Japanese Industrial Standard) screw drivers. Japanese phillips are not the same as our phillips and that is why they strip so easily. I removed my bowl screws last week on my 2005 xt225 no problem. Just do an Amazon search for jis screwdriver. Regards, Tom
[Re: tkerrigan]
#100532
08/06/12 01:55 AM
One thing that will help on stripping phillips screws on Japanese bikes and other equipment would be to get a set of JIS (Japanese Industrial Standard) screw drivers. Japanese phillips are not the same as our phillips and that is why they strip so easily. I removed my bowl screws last week on my 2005 xt225 no problem. Just do an Amazon search for jis screwdriver. Regards, Tom That's interesting to know! A while back I was removing "secondary throttle plates (butterflies)" on my Yamaha FZ-1, as part of a performance modification. The word was out that only a specific brand of #2 Philips screwdriver had the best chance of not stripping the screw heads...something we REALLY didn't want to happen on the bike. It was an American brand though... By the way, we heated the heads with a 100W soldering iron prior to loosening...to soften the loctite glue that the factory used in original assembly. Alexd
[Re: alexd]
#100533
08/06/12 03:36 AM
tkerrigan
Posts: 26 |
The American phillips drivers have a radius at the root of the four blades, the jis has no radius, goes down to a 90° corner. JIS works good on American screws, but the radius on the American driver keeps it from fully engaging the jis screws. I just ordered a set of long and short hex shank jis bits, $45 ouch. They will work well in my Ryobi battery powered impact driver. Regards, Tom
[Re: tkerrigan]
#100649
08/08/12 04:17 PM
Wanabecruisen
Posts: 18 |
Old Berzerker
Topics16,409
Posts147,585
Members5,629
