should I stash some parts?
#153423
07/04/22 10:45 PM
Jerry XT
Posts: 129 |
for my 07 XT225 are there any parts I should buy before they are obsolete or hard to find? air filter, oil filter, brakes….the stuff most likely to need?
JJ 2007 XT225
Re: should I stash some parts?
[Re: Jerry XT]
#153428
07/05/22 02:01 PM
Both the air and oil filters can be cleaned and reused. I'm not sure how common the brakes are.
[Re: Jerry XT]
#153429
07/05/22 02:43 PM
What is your mix of road and off road riding? Also how hard do you ride? This matters on what parts fail and how soon. We kept a lot of spare parts in stock which might be overkill if you're riding mostly street. The pleated barrel filter needs to be inspected for cracks in the pleat folds and the rubber gasket on the end. That said, you can get many oil change cycles out of that filter. I cleaned it with a soft tooth brush and diesel fuel. As for the basket filter behind the oil drain plug, inspect the plastic ring on the base. Then there are the O-rings.
[Re: Jerry XT]
#153441
07/06/22 08:32 PM
Jerry XT
Posts: 129 |
My riding os 50/50 and at this stage I would rate it as easy-moderate riding. Almost no highway, mostly country roads up to 45 mph. My dirt riding is very conservative, getting to old to break my body! Thanks for any ideas!
JJ 2007 XT225
[Re: Jerry XT]
#153443
07/07/22 04:26 AM
kmccarthy
Posts: 234 |
This is a great thread. I suggest we all post the year, mileage of our bikes along with any parts that have broken so far. Maybe we will see some common patterns.
I’ll start 2006, 5K miles
Chain slider Starter relay Carb joint boot Carb float Various carb o rings Rear break linkage spring (got rusty)
-kevin, XT225 2006, BMW F700GS 2013, 2020 BMW R1250GS
[Re: Jerry XT]
#153445
07/07/22 12:55 PM
2006 28,000 miles and counting Carb boot Starter o-rings Valve cover o-rings Seat cover Handlebars because I crashed and bent them. All the usual wear items.... tires, brakes, chain & sprockets, light bulbs, etc.
[Re: Jerry XT]
#153451
07/07/22 05:52 PM
Jeannie and I retired our 2003 XT225s at 15k miles. Almost all trail riding with plenty of crashes which never helped the bikes. That said, those bikes never left us stranded. Parts we kept in stock:
Brake/clutch levers. Disc pads. Speedo, clutch and throttle cables. Headlight bulb. CDI unit. Front fork boots. Fork seals and bushings. Oil filters. Drain plug & oil filter cover O-rings. Oil & grease (Mobil I synthetic) Main fuse (20A blade) Bash plate grommet sets. Spoke set (before we upgraded rear wheels) Wheel bearings (sealed). Air filters. Rubber handlebar grips. Throttle grip plastic sleeve. Spark plug and wire. Horn. Ignition coil. Side cover rubber grommets.
I used to keep valve cover O-rings in stock until I replaced them with silicone ones. That's about all I can remember. I may have kept a small collection of nuts, screws and bolts. I know the heads on the side cover screws got buggered but these can be gotten from a HW store. I replaced the starter O-ring with a silicone one but never stocked the OEM part. That's all I can remember some years back now.
[Re: Jerry XT]
#153454
07/08/22 12:04 PM
Fifty8
Posts: 4 |
2007 1,204 miles
The only part I have replaced is the ignition switch. Lost keys, purely my fault. It won't happen again. I expect my XT to look and work like new 10 years from now, with no parts other than filters and spark plug. Oh, I guess tires and battery need to be added to that list.
“Here is a test to find out whether your mission in life is complete. If you’re alive, it isn’t.” - Richard Bach
[Re: Jerry XT]
#153458
07/09/22 06:43 AM
My XT225 is built out of two different bikes, with a lot of aftermarket parts. I have a huge box of both new and used parts, and a nearly complete parts bike with a 3,000 mile engine. Unfortunately I am reaching the point where I may not be able to ride the XT much longer. I have to stand on something to get on and off, and I am hesitant to ride it very far off road. If something were to happen, it might be difficult to get help, and in my condition I could not walk out.
Right now it seems to be mostly plastics that are no longer available. I sold two stock steel fuel tanks and replaced them with 4 gallon Clarke tanks. Earlier this year, I replaced the swing arm bushings and seals, and all the parts in the rear suspension linkage. Everything was available. Chinese carburetors, pistons, and rings are available, but many people have had issues with them. Many mechanical parts from the TTR225 will fit.
[Re: Jerry XT]
#153460
07/09/22 04:50 PM
Jerry XT
Posts: 129 |
2007 XT225 4485 miles
Worked on my list today On hand: valve cover gaskets spark plug oil filter oil filter cover oring oil drain plug oring oil strainer air filter air filter oil (notoil) air filter cleaner (oxiclean) fuse air filter case gasket grease/lube Buy when needed: tires oil battery brakes What I replaced since 2007 not onhand: tires battery fuel knob oil So far this bike has not failed me on many 90+ mile rides in mountains 8000’ - 13000’
JJ 2007 XT225
