Re: Racing/erratic idle
[Re: Bloodmouse]
#138100
08/24/17 03:19 PM
Bloodmouse
Posts: 21 |
Thanks Alexd...I'll keep that in mind. I'm waiting on some throttle and carb parts before I can get it back together and running. In the meantime I replaced the rear brake shoes, hopefully got it readjusted correctly, and hopefully remedied the Satan's Howl that came from the drum at the mere thought of using it.
[Re: Bloodmouse]
#138103
08/24/17 08:42 PM
cogitech
Posts: 189 |
I got the pilot jet out today and replaced it with a 42.5. Also went up to a 132.5 main. Tore the carb down again for a more thorough cleaning too. I'm waiting on some other parts before I can get it back together. 132.5 might be way too big, unless you are planning on pumping pure O2 into the intake. In all seriousness, I recommend going to a 130 if you are running at or near sea level, or a 127.5 if you are significantly higher than that. I ride between 3500 and 5000 feet mostly, and I found the 130 to be too rich (even with a big hole in my air box, a UNI filter, and the Z1 exhaust mod).
[Re: cogitech]
#138105
08/24/17 09:58 PM
I also believe 132.5 will be too large...unless PERHAPS you remove the snorkel and run E-15 gasoline.
[Re: Bloodmouse]
#138113
08/25/17 06:09 PM
Bloodmouse
Posts: 21 |
I've been getting radically different advice on the main jet size. Most have recommended 132.5 or 135 for a bike with exhaust and airbox mods. I live around 3200 feet, with riding up as high as 6500-7500, but most riding will be between 3500-5500. S
[Re: Bloodmouse]
#138114
08/25/17 06:12 PM
Bloodmouse
Posts: 21 |
Stock it has a 130, and I've been battling a lean condition in the pilot circuit, which I'm combating with a 42.5 pilot jet. I'm tired of taking this carb on and off, and I still plan to mod the exhaust. Beings that I haven't yet perhaps I'll throw the 130 back in for now.
[Re: Bloodmouse]
#138115
08/25/17 06:15 PM
Bloodmouse
Posts: 21 |
I'll be running 91 non-ethanol
[Re: Bloodmouse]
#138116
08/26/17 01:03 AM
My pardon...I thought your stock jet (like mine) was #125. If it was #130, then one "click" up (#132.5) is fine for various mods that lean things out slightly.
Check it out for yourself:
On a THOROUGHLY warmed up engine, on a straight road with zero cars and people, go into 4th gear at 20MPH and suddenly twist and hold the throttle fully open until it screams at full speed in 4th. If it burbles at high RPM, you're too rich on the main jet. If it stumbles and/or won't pull up to high RPM, you're either too lean or your needle needs to be shimmed (to make the midrange richer)...or both.
Alexd P.S. 91 octane non-ethanol is fine
[Re: Bloodmouse]
#138118
08/26/17 04:57 AM
Bloodmouse
Posts: 21 |
I put the 130 back in for now. Until I do the exhaust mod, then maybe I'll need a bigger main. For now all I've done is pulled the snorkel out.
[Re: Bloodmouse]
#138120
08/26/17 02:50 PM
woodratt
Posts: 9 |
when i first got my 02 xt it had been sitting for a long time . I went through much of what you are experiencing . my problem turned out to be a bad o-ring in the intake manifold .
old norton/triumph rider
[Re: Bloodmouse]
#138121
08/26/17 05:33 PM
I put the 130 back in for now. Until I do the exhaust mod, then maybe I'll need a bigger main. For now all I've done is pulled the snorkel out. The effect of removing the snorkel is, in my opinion, about equal to the leanness created by the Z1 mod. Other things working properly, there is a small power/response gain. Alexd
